Front Parking Sensor
i do know the Rcf regarding the front parking sensors doesnt have them in the very front only on the sides but i do think you have to turn of the front
there is a button on the lower left of your dash with a "P" on it, this turns the parking sensors on and off, it also related to a green lite "P" on your dash cluster when active. Front only work at speeds below 7mph,, rear only work in reverse by default.
the RC-F only has sensors on the corners not directly in front, so it doesn't detect anything immediately in front of the vehicle only on the outer edges.
the manual explains how to set the sensitivity settings on them via the navigation system. You can also have the dealer (or use the Carista App) activate them so the front and rear are always active at any speed in any gear, I have mine set this way, it really shows you how often a-holes tail gate you, they will activate when a car is closer than 7 inches, and mine go off all the damn time, especially in stop and go traffic. 7 inches may sound like a lot of distance, but 90% of people can't walk between 2 cars parked 7 inches apart, so that gives you an idea of how douchey people really are.
Rear parking sensor range
NARROW / WIDE
Mute parking sensor when stationary for more than 3 sec.
YES / NO
Activate parking sensors in neutral (N)
YES / NO
Enable front parking sensors when in reverse (R)
FRONT / OFF
Enable rear parking sensors when in neutral or forward gear
REAR / REAR CORNER / OFF
NARROW / WIDE
YES / NO
YES / NO
FRONT / OFF
NARROW / WIDE
Thanks I forgot about this one. default on the front for the RC-F is Narrow, changing it to wide covers most of the front of the car except the dead center.
This is why I don't have an issue with them picking up the disabled parking signs in parking stalls. A lot of RC-F users complain the front are useless, but changing to wide band on the range dramatically improves their usefulness.
NARROW / WIDE
when I first got the car I remember the fronts being useless, then I tweaked things with the carista and now they pick up nearly everything in front of the car, so I'm pretty sure one of the changes in the carista caused that. There is/was a noticeable difference in their behavior.
1 / 2 / 3 / *4* / MAX
Temporary parking sensor muting speed
AUTOMATIC / 15 KM/H / *20 KM/H* / 30 KM/H
Display temporary parking sensor muting status
*YES* / NO
*YES* / NO
*FRONT* / OFF
REAR / REAR CORNER / *OFF*
*YES* / NO
*YES* / NO
*FRONT* / OFF
- Activate parking sensors in neutral (N)
- Enable front parking sensors when in reverse (R)
- Enable rear parking sensors when in neutral or forward gear
I did a test this morning before you posted. I used 1st WIDE then NARROW, with NO difference but maybe I have to do your 3 changes as well.
1st: I put a 32 gal trash can directly in center line and NEVER got a detection at any distance.
2nd: I moved the can 12" left and was able to get a detection.
3rd and 4th: Then I tried something with a flatter surface. I used an\ (old billiard cue case about 8" wide and 3ft tall, like a parking barrier. See attached pic.
Same response distance in NORMAL and WIDE Rear setting. Starts sensing at about 23" (x direction) with edge of the billiard case on a 14deg angle from the sensor.
5th: Then I did try driving about 3" farther left and the never got a detection.
Maybe someone has a detailed spec/diagram of what the sensor can do and what the setting changes will do.
I did find a Lexus doc that says that REAR Narrow is 23.62" and WIDE is 59.06". but NO DIAGRAM of where measured.
It called this setting RR BUZ RANGE (rear buzzer onset range)
In the pm I made changes (like id MEDS), BUT is saw no change in the coverage with Narrow or Wide. I put some chalk on the floor shows the limit or the sensor.
last picture attached is rear test and show Wide increased the distance by about 2x. The RCF user manual shows distance ranges, clearly NO front center coverage. (page 258)
and the diagrams top and side view on page 259 shows about what I measured. I did test an example of a big curb (8" high). Sensors could not see it.
- Enable rear parking sensors when in neutral or forward gear (R)
- Tested Narrow and Wide (I guess Lexus "Wide" just means wider along the center line or that the starting threshold is farther from the bumper for the rears not a wider beam)
