Spark plugs 2015 Lexus RCF
Old Jun 10, 2024 | 10:36 PM
AlvarezRCF's Avatar
AlvarezRCF
10th Gear
Default Spark plugs 2015 Lexus RCF
Hello fellow members, My spark plugs are due for a change. Can someone recommend a brand and also I noticed some of them you need to adjust the gap which I don’t wanna do. I’m looking for a direct fitment without having to mess with the gap. Thanks! 🤙
Old Jun 11, 2024 | 12:54 PM
KennyFSU's Avatar
KennyFSU
I changed my plugs at 107k and replaced them with NGK 93420 LFR6BHX Ruthenium HX; they were pre-gapped.
Old Jun 12, 2024 | 10:24 AM
JT2MA71's Avatar
JT2MA71
Are you switching from OEM spark plugs? If so, why? OEM brand is Denso.
Old Jun 13, 2024 | 01:21 PM
konichiwa3's Avatar
konichiwa3
I totally agree there ^^^ , don't see any reason to change. Stick with OEM Denso, they do make the best stuff out there. I did change to the racing variant which are amazing, you will pick up some low end torque and a discernable higher pitch exhaust sound along with some nice down shift notes. Only drawback is the racing variants have half the lifespan of the regular ones at best.
Old Jun 13, 2024 | 01:27 PM
LoSt180's Avatar
LoSt180
OEM is Denso 3515 (FK20HBRJ8). Proper gap is 0.8mm if looking at other brands.
Old Jun 13, 2024 | 04:18 PM
AlvarezRCF's Avatar
AlvarezRCF
10th Gear
I was looking at those but they told me I have to gap them to the correct specs which is 0.31 for the RCF.
Old Jun 13, 2024 | 09:02 PM
konichiwa3's Avatar
konichiwa3
.....or get a tune. Is your engine stock? Again it begs the question, what are you trying to achieve? The OEM Denso ones are pretty darn good
Old Jun 14, 2024 | 02:52 AM
JT2MA71's Avatar
JT2MA71
Get the OEM ones and you won't need to mess with the gap as they come pre-gapped (which is what you're looking for) Won't hurt to verify them just in case though. They will last a very long time too. 0.031" or .8mm (.787mm) is the proper gap.
Alternet
Oct 15, 2025 06:46 PM
Lingus
LS - 5th Gen (2018-present)
Aug 5, 2024 12:51 PM
badman5
Aug 4, 2023 04:20 AM
cheez
Apr 20, 2010 05:43 AM
