Hey guys I'm new to this forum and I've looked through a lot of the threads pertaining to swaps but I haven't seen anything on a possible lq swap for a gs300. Has anyone heard of one or if it's possible. Thanks guys
Thanks crashmonk. My main concern was if the lq9 or lq4 would fit. But if they will fit that's perfect. Now with transmission would it be best if just go with t56 still?
Best? Absolutely the best. If you can afford the 2k for it...
I used a $100 Chevy Colorado AR5 trans with a modified factory bell housing. But that's a truck tranny so It shifts like a truck
IMHP the next question is: how important is an aluminum block (least disturbance to front/rear weight distribution, front spring rate)? Big $$ difference.
Possible, but I would guess not by much.
The CG is farther back, if the bellhousing position is same.
For a high boost engine (1,000 hp) I think iron is preferred, but for NA the weight saving of aluminum block is huge. Look at the money spent on carbon fiber, titanium in terms of $ per lb.
Shifts like a truck, meaning effort, or ratio spread?
Both. It's mainly the 1-2 shift, seems when it's cold it will shift quick. After its warmed up, you can tug on that shifter and while it never grinds, its NOT gonna hit 2nd fast.
1st gear is 3.75 so its less than ideal for most sports cars. I have a GS430 diff though, so I can hit 45mph in 1st.
As for the weight difference, I've researched that the 2jz and iron block LS engines are within 50 lbs of eachother. Negligible. If you were swapping your Caterham or lotus, I could understand spending the extra scratch. But not a lexus
That 1st gear is how the 6MT Supra V161 with 3.742:1 pulls that 3.13:1 axle. Of course, it's nearly useless with mid-3.00 gears and up.
The 1-2 shift RPM loss is almost identical between the V161 and AR5.
That suggests something is binding, has it been apart? Linkage rubbing something? Have you tried adjusting the clutch? Any chance of thrust washers being swapped, non-OEM gaskets used?
WRT weight: I know people who have cheerfully spend $10. per pound to drop weight, and it wasn't in the nose.
I guess the ratios arent terrible. It has a decent overdrive of .73.
It was a junkyard trans with 80k miles on it, all I did was space the throwout bearing/slave out to allow full disengagement of the clutch. It does fully disengage, but I thought that the disc takes a while to spin down. The shift lever isnt rubbing on anything. I am considering taking it apart this winter to check out my synchros and may try the Hummer H3 Carbon synchros... This trans has triple cone synchros I expected It to perform better.
I should also mention that my shift lever is goofy. I should make an actual extension but its really just a long lever.
I bought some Amsoil 75w90 MTF yesterday as a last resort. I'll put that in soon and maybe It will be a whole new tranny! I seriously doubt that...
