Swap
Old Sep 13, 2016 | 07:44 AM
Izaig95's Avatar
Izaig95
Default Swap
Can anyone tell me if the 2jz motor will fit in a 08 ES350? I was thinking of swapping if it did fit.
Old Sep 13, 2016 | 10:28 AM
Blue Moose Engineering's Avatar
Former Sponsor
I'm in because I want to hear the answer to this question
Old Sep 13, 2016 | 08:14 PM
Izaig95's Avatar
Izaig95
Yea, if only i could have someone answer. It'd be very appreciated
Old Sep 14, 2016 | 06:16 AM
Clutchless's Avatar
Clutchless
I wondered what a 2jz motor was (as I am sure others also wondered) and found that it is an inline 6 cylinder engine. I doubt an inline 6 would fit or be adaptable to fit into the ES and mate to a transmission. I would think a few simple measurements could help resolve this issue. I also wonder why anyone would want to do this swap?
https://en.wikipedia.org/wiki/Toyota_JZ_engine
Old Sep 14, 2016 | 06:52 AM
Former Sponsor
Ya it all depends on what you mean by "fit".
If you mean, mostly bolt in and work using shelf parts, then no, that engine certainly would not fit. Your car is front wheel drive and the 2jz has never been used outside of a rear wheel drive configuration as far as I know.
Its also about bout a mile long so dimensionally it just wouldn't work well in FWD.
Now, if by fit you mean, make it work using money and skill then I'm sure it could be done. You could convert your car to rear wheel drive for many thousands of dollars.
The fact that you have to ask tells me that you aren't a skilled fabricator so you'll be paying someone to do it for you. I'd guess somewhere between $35-$50k for parts and labor.
If if you want a car with a 2jz buy an is300.
Old Sep 14, 2016 | 05:47 PM
RXGS's Avatar
RXGS
I remember a time when I would see this question monthly on the then, 2nd gen ES section and 3rd gen ES section. I didn't realize how little you can pick up an ES350 for these days.
Old Sep 15, 2016 | 09:04 PM
Former Sponsor
Haha yes there is a version of this question found at every car forum on the entire intarweb
Jay hall
RC - 1st Gen (2015-present)
Aug 11, 2015 02:00 PM
All4sho350
CT 200h Model (2011-2017)
Feb 15, 2015 01:17 PM
Markysc4
Sep 6, 2012 10:12 PM
240swapped
Apr 27, 2008 09:41 PM
Inabj2
Oct 29, 2003 05:10 PM
