IS200t tune
We will be sending out tune files to everyone this evening with those IDs. Thank you for your patience. And thank you to the customers who got us the additional ECU info we needed (like on the NX200T)
So, we have a question. After we get through this round of setting up stage 1/2 EROM 1.01 tunes, we will be working on some new features (that are already in the works)
What we were thinking, and wanted to get some feedback on from the community >
Would you guys be interested in having a different tune build into our flash, depending on mode.
Here is what we mean >
when you put the mode selector into "eco"
the ECU will change to a different map
ECO >
Boost target
Ignition table
Fueling
VVT
Normal> Different map (map 2)
Different boost target
Ignition table / fueling / VVT
Sport > Map 3
Different boost target / ignition timing / Fueling / VVT
(also each will have it's own shift tables as well)
ECO for economy;
SPORT for the aggressive maps, like a race/track mode;
NORMAL for a show/exhibition mode including the exhaust burble/popping/backfire you mentioned was possible in a past post.
Not sure if this would be possible but starting the car in "Valet mode" would be really sweet and valuable to some. Personally, I purchased your tune for the performance, anything extra is icing on the cake.
If you need any help, questions, troubleshooting, anything please contact us by support@ovtune.zendesk.com. I will be available all weekend.
I am working on other ECU IDs to get to everyone this weekend.
Here are my initial thoughts and comparison to the TTi Stage 2 tune:
If you take nothing else away from this, the OV Tuneis better for driving than any of TTi's tunes. On the butt dyno, the TTi made more power, but it's difficult to tell because TTi's was stage 2 whereas OV is stage 1; furthermore, TTi is all midrange (3000-5000RPM) whereas OV is much more linear. The throttle on OV is more responsible and has less delay before it goes at 2500 when you hit boost. Finally, the transmission tune holds revs better than TTi. I can't tell if it downshifts quicker as it's fast enough for me, but it definitely upshifts faster.
The way I described the car on OV Stage 1 to Mat is: it's like a less torquey 328i. While that may not sound fantastic, the 328i is all torque which makes the driving experience a little jarring sometimes.
Cheers!
EDIT EDIT EDIT Apparently this isn't the final version yet, with TCU unchanged! EDIT EDIT EDIT
THE GOOD:
- Throttle response from a standing start is instantaneous.
- Seems to pull a lot harder than TTi stg 1 from 4-5.5k.
- Engine sounds almost as smooth as the factory tune and not as coarse as TTi’s.
- No CEL on my drive to work. I’m currently on RON 100, which converts to about US 95.5 octane. No downpipe as well.
- One price for both ECU + transmission tune. Had to pay extra for TTi's.
WHAT COULD BE IMPROVED:
- Throttle response from a rolling start of around 30-40 Km/h seems a little sluggish.
- Transmission is not eager to downshift even at what feels like 80% accelerator input, feels like an ’07 Camry 3.5 V6 we used to have, which would rather slug up from 2k rpm rather than downshift.
- While rev limit is still stock, auto-upshift in M mode still seems to be there.
Transmission issues may be related to 6AT vs IS's 8AT and might be able to be solved by implementing the Tacoma 6AT improvements. Will keep everyone posted on further observations.
Last edited by chezgk; Apr 5, 2019 at 07:33 PM. Reason: Apparently this isn't the final version yet!
ECO >
Boost target
Ignition table
Fueling
VVT
Sport > Map 3
ECO: Conservative VVT and fueling, more of that simulated Atkinson cycle thing that Toyota touts to save fuel, normal shift tables, maybe even more ECO than the factory tune's ECO depending on consensus. This can act as valet mode as someone requested.
NOR: Performance VVT and fueling, normal smooth shift tables
SPO/+: Performance VVT and fueling, performance shift tables, transmission solenoids activating a little more aggresively
- With 1.01, what variations were introduced among modes?
- Are there provisions to alter steering assist in the ECU tune file, or is that located in another vehicle control module?
I am not sure if this simple trick works on a NX, you may give it a try and test it out.
ECO >
Boost target
Ignition table
Fueling
VVT
Sport > Map 3
ECO> replace it with the stock NORMAL mode.
Here are the reasons:
- I never use the ECO mode because it just makes the car feels very lazy even for normal driving.
- I prefer to keep the stock NORMAL mode because I think it's advantageous to retain the Auto-Atkinson mode for light engine load scenarios (e.g. highway cruising)
SPORT> OV's more aggressive tunes
just my 2 cents.
On another note, Normal and Sport modes seem to be flipped in my vehicle's tune, with N feeling way livelier than S. I'm still waiting for the full/non-test tune from OV.
and yeah the transmission is tuned really soft from the factory during WOT upshifts. you can feel the clutch packs slip. i wonder how crisp tuning can make that. can it shift like the 8 speed in the RCF/ISF? Is it just tuning that distinguishes the two transmissions?
PasswordJDM has a lot of carbon fiber engine pieces of the 200t.
In the meantime, I installed an FTP charge pipe earlier this week. Low end torque seems to have diminished, but the top end seems to pull a lot harder. Did anyone notice this as well? I speculate that this stemmed from the larger charge pipe diameter causing both lower intake velocity for a given psi at the low-end and larger flow capacity at the high-end, though I don't have any hard data to prove it.
