IS200t tune
Old Feb 12, 2018 | 02:11 AM
  #2701
Nuke's Avatar
Nuke
Old Feb 12, 2018 | 06:46 AM
  #2702
loophole35's Avatar
loophole35
I'll take a black one. I guess I'll be contacting Tony some time soon.
Any more updates on the hybrid turbo?
Old Feb 12, 2018 | 07:12 AM
  #2703
Sheddy's Avatar
Sheddy
Originally Posted by SubieChik
Sheddy I saw you praise the BMS Stage 1 box.....which I was excited about since I already bought it. But then as I read on further I saw that you and a few others have switched over to the TTI Stage 2+ and now I am wondering if I made a mistake......especially after seeing Nukes dyno results holy cow.
I have an Injen intake and from the stock DP back is straight pipe with 2 Vibrant resonators inline. I will be adding a PPE catless DP in the future also. So now I ask, with the few bolt ons I have, which route should I go? TTI or BMS? Please say BMS as I already have it coming LOL just kidding! But seriously, I just am looking to get as much as I can out of this motor/turbo...safely obviously. I don't want to hear the whole crap about if you wanted power you should have bought something else.....no crap. If I wanted power I WOULD have bought something else or shoot I would have just kept my husbands F when he sold it. I have had the 200t now for a little over a year and I can't wait to see what it can do.
Sorry for the confusion lol. The first time i had the BMS tested was on the stock motor, so since i added the down-pipe i wanted to re-test to compare the results. The BMS is an awesome plug and play tuning product for the price. I've seen really good power gains over stock and love the fact that the boost settings can be increased once bolt ons are added. The TTI on the other hand would give you more power since its an actual re-flash tune, but is more expensive and a little more complex to install. I also hope Nuke's response was able to clear things up.
Originally Posted by 808NXF
Been following this thread for a couple years now but this is my first time posting. I’m curious if anyone has come across this tuning company?
http://tuningtechfs.com/lexus-is-200...-2016-present/
TTFS requires ECUs to be mailed in for tuning.
Thanks for posting!
This company had this posted for some time, but i've yet to see any results or feedback regarding their product on their website
Old Feb 12, 2018 | 07:17 AM
  #2704
Sheddy's Avatar
Sheddy
*UPDATE*
I get a lot of inquries regarding our tuning options, so i've decided to add a couple informative links on the 1st page of this thread. I hope this helps
Old Feb 12, 2018 | 07:33 AM
  #2705
Nuke's Avatar
Nuke
ya i like black very stealthy
hybrid testing is on going and i think TTI is gooding even bigger on the compressor wheel since they found area for
impro on the prototype
Old Feb 12, 2018 | 08:16 AM
  #2706
PGARazor's Avatar
PGARazor
Talking
Originally Posted by Nuke
Yup, emailed Toni for options of colors and finishes.
Old Feb 12, 2018 | 08:29 AM
  #2707
loophole35's Avatar
loophole35
Any numbers on the initial prototype?
Old Feb 12, 2018 | 11:30 AM
  #2708
Nuke's Avatar
Nuke
only Tony knows that and i recon he wont spill the beans just yet
Old Feb 12, 2018 | 11:31 AM
  #2709
Sheddy's Avatar
Sheddy
I haven't heard anything. I am still waiting for Stage 2+ to be updated with the limitations removed. Last i heard it was an ongoing process.
Old Feb 12, 2018 | 11:45 AM
  #2710
Sheddy's Avatar
Sheddy
Thinking of using the DEI gold reflect tape on my intercooler (just accessible areas) like the TRD TG20.
Old Feb 12, 2018 | 06:20 PM
  #2711
Nuke's Avatar
Nuke
Nice idea but only for looks, however if your thinking it will add some performance then I guess think again :P if you want to enhance cooling then way to go is to change the IC radiator since our car has two radiators one is responsible for cooling the liquid from IC
Old Feb 12, 2018 | 10:44 PM
  #2712
Sheddy's Avatar
Sheddy
It will definitely add some “cool” appearance factor, but from the reviews I’ve read is that it actually does help keep the temperature down a bit. Using this on our intercooler can help with excessive engine bay heat essentially lowering the IAT which is a plus. I don’t want to mess with the intercooler coolant radiator, but If this is good enough for TRD to use it then why not try lol.
Old Feb 13, 2018 | 12:22 AM
  #2713
Nuke's Avatar
Nuke
lol valid point of view but I think they added it just to have more "modification" to justify the price tag and changing the radiator is not a big deal since so many options for even coolants are out there that will outperform the stock
Old Feb 13, 2018 | 03:09 AM
  #2714
loophole35's Avatar
loophole35
I believe the inercooler radiator is sandwiched between the condenser and engine radiator. So upgrading it may be more difficult that you think.
Old Feb 13, 2018 | 04:13 AM
  #2715
808NXF's Avatar
808NXF
Not sure about you IS guys, but the NX has tons of room behind the grill. I say add an upgraded heat exchanger in front of the radiator and leave the stock IC heat exchanger in place. Use the stock heat exchanger solely for cooling the turbo and the upgraded heat exchanger can be dedicated to an upgraded intercooler. Frozenboost.com has pretty good looking kits that hold large volumes of coolant and come with the very reliable and high performing Bosch Cobra (used in factory supercharged Ford Mustangs).
I plan on picking up one of their kits, fabbing a custom charge pipe+intercooler to throttle body pipe and boring the throttle body to create a consistent 2.5” plenum. I understand larger tubing might cause a slight pressure drop for now but I also don’t plan on keeping the turbo stock once tuning progresses.
