IS200t tune
Old Jul 12, 2017 | 12:10 PM
  #1201
IS200TFOWL's Avatar
IS200TFOWL
Originally Posted by daniellina
I'm going to mix 2 gallons of e85 and 12 gallons of 93 to see the difference. i have full exhaust and the downpipe.
I feel a slight slighttt difference, Tony specifically introduced light knock with added timing which is what would be needed to reap benefit of ethanol. Your car should drive fine with it but you might actually lose power vs gain. Try it out tho, make sure e85 is actually e85 because in Arizona, e85 is really e51..........
Old Jul 12, 2017 | 03:20 PM
  #1202
zcon's Avatar
zcon
yeah, that is why a flex fuel sensor is the best solution, when the e85 isnt quite 85% the ecu adapts and is tuned for every percentage from 85% to 0 percent. Also gives flexibility for when an e85 pump is not near by
Old Jul 13, 2017 | 06:20 PM
  #1203
gbgary's Avatar
gbgary
Originally Posted by Sheddy
lol, ok Sea level, but soon.
was wondering if there was a disaster i missed.
Old Jul 13, 2017 | 08:38 PM
  #1204
daniellina's Avatar
daniellina
i filled up and calculated and e30 mix here is a 3rd gear pull
Old Jul 16, 2017 | 11:29 AM
  #1205
Eclisse1's Avatar
Eclisse1
TTI Stage 1 + K & N Replacement Air Filter 33-2452. Manual gearbox, Eco mod, not a highway and not a city. 300 km of very quiet driving, 3 people in the car. I think it was sensational !!!
Old Jul 16, 2017 | 01:58 PM
  #1206
E46CT's Avatar
E46CT
^What? lexus makes this in manual gear box?
Old Jul 17, 2017 | 05:06 AM
  #1207
daniellina's Avatar
daniellina
I think he means that he was using the manual mode...
Old Jul 17, 2017 | 09:33 AM
  #1208
Nuke's Avatar
Nuke
Hey guys,
sorry been away for a while, actually been working closely with Tony as seems he still is having trouble to iron out the problem with my boost, we have changed the solenoid and few other things and tried over a dozen of tunes and still no luck as it seems like the car is happy making a max of 1bar at best, am starting to think its related to the ROM version, so he is checking with Bitbox which is making the turning software to look into that as my ROM version is different from all of you guys....lucky me
Nuke
Old Jul 17, 2017 | 10:29 AM
  #1209
Eclisse1's Avatar
Eclisse1
Sorry, manual transmission mode
Old Jul 17, 2017 | 11:55 AM
  #1210
daniellina's Avatar
daniellina
Originally Posted by Nuke
Hey guys,
Nuke
Hopefully you can solve this issue soon.
Old Jul 17, 2017 | 05:10 PM
  #1211
Sheddy's Avatar
Sheddy
I'll have to test the 93 + E85 mixture soon!
Old Jul 17, 2017 | 11:30 PM
  #1212
TTITony's Avatar
TTITony
Former Sponsor
Hello everyone,
I have a small update or rather a clarification as it seems people are still confused about the Throttle limitation topic.
Actually in both our tune options (Stage 1 & 2) throttle limitations that is applied by default is completely removed, in other words throttle works WITHOUT any limitation and there is no doubt about that, we even performed extensive testing with some of our users like Nuke and he can confirm the same, and all this was done without scarifying drivability and comfort whether ur on the highway or in the parking lot because we care about balance linearity, and just to further clarify this point the ECU is completely responsible for the throttle limitation and thats the reason we can fully unlock this part of the tune
I really hope that this clarifies once in for all the confusion around this topic.
Thank you all
Old Jul 18, 2017 | 12:13 AM
  #1213
Nuke's Avatar
Nuke
Originally Posted by TTITony
Hello everyone,
Thank you all
Thanks Tony, I have tried to clarify the same few times but it seems people only take it seriously when it comes from you directly :P
Old Jul 18, 2017 | 12:04 PM
  #1214
Sheddy's Avatar
Sheddy
Off topic, but
2.0 Turbo w/ 252 hp (187 kW) and 273 lb-ft (369 Nm) of torque
http://www.carscoops.com/2017/07/201...iled-with.html
Old Jul 18, 2017 | 01:32 PM
  #1215
E46CT's Avatar
E46CT
Hello everyone,
Thank you all
Awesome. Thanks for the tight words. The reason why this clarification is important is because nobody really ever clarified both stage 1 AND 2 *completely* remove the Lexus 30% throttle limitation. So now that we all know the throttle will open 100% from a dead stop when floored is absolutely important.
I might consider your tune now but still afraid of bricking something. I'll wait to see how others do first =p Maybe someone can post a video of the process from beginning to end to take the mystery out of it.
