IS200t tune
Old Sep 1, 2017 | 09:19 AM
  #1561
Sheddy's Avatar
Sheddy
Originally Posted by zcon
Now numbers like these seem much closer to what this 2.0T should really be doing! 325wtq // 280whp would do this car justice. Add some e85 and crank those numbers a bit higher
An increase in 5 PSI more (currently at 19 PSI) would do the trick. My VW 1.8T ran 22 PSI with the APR tune and the turbocharger lasted, so hopefully this one can handle it as well.
Old Sep 2, 2017 | 08:58 AM
  #1562
Sheddy's Avatar
Sheddy
0-60 with traction off and 2000rpm launch.
Here's the video of the boost gauge reading from a dead stop.
Old Sep 2, 2017 | 11:53 AM
  #1563
daniellina's Avatar
daniellina
Thats 6 seconds flat 0-60
Old Sep 2, 2017 | 01:31 PM
  #1564
IS200TFOWL's Avatar
IS200TFOWL
Are you not engaging sport mode?
Old Sep 2, 2017 | 02:29 PM
  #1565
Ricoo's Avatar
Ricoo
Little trick to keep the "trac off" screen from replacing the boost gauge screen. After disabling the traction, press the return button once to go back to the boost gauge screen. While on the boost gauge screen, hold down the return button. trac off Screen pops back up after 7 seconds so just press and hold anytime before that. This will keep the "trac off" screen from popping up. Oh and don't try to turn while holding the button down. 😅
Old Sep 2, 2017 | 05:31 PM
  #1566
Sheddy's Avatar
Sheddy
I feel as though the sport mode would not make a difference with this test IMO. I'm allowing the transmission to shift on its own on a straight line, so I'm not taking advantage of the aggressive shifting. I will try it again on sport mode and see if it makes a difference.
You can say that, although I feel this is not accurate enough. The 2000rpm launch does trim that time a bit!
Old Sep 4, 2017 | 04:47 PM
  #1567
john55657's Avatar
john55657
Not to hijack this.. Does anyone know how to contact OV? I have tried to reach him to no avail. Would be nice to know if my OBD tool shipped
BTW, just tried sales at ovtuned dot com. The email is disabled.
I am excited!! Cant wait!!
Old Sep 4, 2017 | 05:13 PM
  #1568
Sasnuke's Avatar
Sasnuke
Did you try this one: orangevirus101@gmail.com
Old Sep 4, 2017 | 11:04 PM
  #1569
Lexus3GIST's Avatar
Lexus3GIST
Beginning the process to purchase Stage 2 Tune from TTI and the SPower Downpipe. (Just sent an email to tony)
Already have an Injen intake. 17' IS200T F-Sport. I'll keep you guys updated. Will try to find a dyno and give you guys power results. I live in Houston, TX f you're interested in elevation/etc.
Old Sep 5, 2017 | 08:12 AM
  #1570
Sheddy's Avatar
Sheddy
I've been told that they are not great at communication due to being super busy. Try that other email.
Awesome! Hope things are getting better in Houston, we are on the lookout for Irma here in south FL.
Old Sep 5, 2017 | 09:45 AM
  #1571
gbgary's Avatar
gbgary
hope you have some family/friends inland on high ground. good luck!
Old Sep 5, 2017 | 11:55 AM
  #1572
Sheddy's Avatar
Sheddy
Thanks!
Old Sep 5, 2017 | 01:23 PM
  #1573
IS200TFOWL's Avatar
IS200TFOWL
They had to wait on software dongles, should be shipped today
Old Sep 5, 2017 | 02:20 PM
  #1574
E46CT's Avatar
E46CT
Correct sport mode has no effect when the car is floored. It will not make the car any faster and the shifts will not behave any differently under full throttle from a start. And that's the same for just about every car ever made.
Old Sep 5, 2017 | 02:51 PM
  #1575
IS200TFOWL's Avatar
IS200TFOWL
I understand thats a safety issue non the less. I just question whether the transmission shifts faster, holds gear longer or if its as responsive when you manually shift. I find i get better 0-60 times when i shift into 2nd at 5.5k, just before torque falls, and in sport mode the transmission doesn't delay or hesitate when i hit my shifter. Can't say the same for normal mode
