Photon's GS300 Turbo project
Old Jul 8, 2011 | 04:05 PM
  #106
BrianLex's Avatar
BrianLex
Thats alot of work,but it looks great.
Old Jul 10, 2011 | 12:49 PM
  #107
qphoton's Avatar
qphoton
Default injectors and coils wiring pics ..
It was last work under hood.
Old Jul 26, 2011 | 08:35 AM
  #108
qphoton's Avatar
qphoton
Default new pics ...
new PTP chrome turbo blanket received ...
Old Jul 31, 2011 | 09:27 AM
  #109
qphoton's Avatar
qphoton
my control box (AEM EMS, AEM TwinFire, AEM P&H driver, AEM W/M injection, AEM wideband controller, MAF-emulator, relay boxes, etc):
all works are finished under hood (all wiring finished, stock ECM closed):
new rear optics installed:
Old Jul 31, 2011 | 11:01 AM
  #110
Cranix's Avatar
Cranix
That's a Beautiful engine bay, Unbelievable!!!
What are the power specs.?
Old Jul 31, 2011 | 11:27 AM
  #111
Justin2JZ's Avatar
Justin2JZ
Those lights. Noooo.
Old Jul 31, 2011 | 12:10 PM
  #112
DeanGS's Avatar
DeanGS
Nice build!
Curious about the GT3788R, what material are the wheels?
With a .99 turbine the pull should be fairly linear, not too punchy, would like to see a boost graph.
What is the highest octane rating on pump gas where you are or are you planning on running something else?
I would ** think ** that you could have run another half point in static compression for more off boost driveability, am curious as to why you choose the compression you did.
Also, what stall converter are you using?
Thanks again for the thread and the insight!
Old Jul 31, 2011 | 07:08 PM
  #113
qphoton's Avatar
qphoton
Thanks, i think 600-650 on pump gas and 700-750 on c16 ..
Originally Posted by DeanGS
Nice build!
it is stainless steel 7 blade wheel,
here is 98 pump gas, something like 91 in usa, also i will order c16 for track days ..
cr 8.07 because my goal is 2.1 bar on pump gas ..
A650E and TC was fully rebuild by Import Performance Transmission (USA), stall speed 3400 ..
Old Jul 31, 2011 | 07:33 PM
  #114
SNiiP3R's Avatar
SNiiP3R
Ниче так конструктор ты собрал! )))) Very nice build man, keep up the good work!
Old Jul 31, 2011 | 08:14 PM
  #115
Justin2JZ's Avatar
Justin2JZ
Wow 98 oct. I wish it was like that here in FL. We only have 93.
Old Jul 31, 2011 | 10:52 PM
  #116
DeanGS's Avatar
DeanGS
3400 stall, nice. They rebuilt a stock converter and kept the lock up? If so, very nice.
It'll be interesting to see how the turbo spools, 30lbs should be VERY fun!
SRTGS300: On the octane, the value is different depending on how it is calculated. Using the US method we only have 91 octane in Cali thanks to the USELESS ethanol additive (not to mention oxygenated fuel). CARB: "Make the fuel burn cleaner but far less efficient so they'll have to burn more of it counteracting the "clean effect"". Read: "more tax revenue for the state AND higher pollution."
Old Aug 1, 2011 | 12:57 AM
  #117
qphoton's Avatar
qphoton
91 oct in usa little bit better than 98 oct here, but your 93 oct is a dream for guys from Russia
Old Aug 1, 2011 | 12:57 PM
  #118
sakataj's Avatar
sakataj
those tails look terrible man....especially for all the work you put in
I DONT....98 oct over there AS THE OP SAID IS LIKE 91 IN THE US, so the 93 we have in the US would be like 100 octane to them
Old Aug 1, 2011 | 01:15 PM
  #119
Justin2JZ's Avatar
Justin2JZ
Okay, I understand now.
Old Aug 1, 2011 | 08:38 PM
  #120
qphoton's Avatar
qphoton
I can't tell that in delight from design of this optics, but workmanship was pleasant to me, well and while the car hasn't resulted in a full order, we will look.
