Photon's GS300 Turbo project
Working too much is def something i can relate too. No i'm not comunist...great work on the car top notch!
2JZ + AT* + 4WD* + custom turbo manifold*** + APEXI Power FC**
* builded by HARVEST
** tuned by HARVEST
*** designed and assembled by SOARA
http://www.youtube.com/watch?v=n7UuffIej_U
** tuned by HARVEST
• Engine 2JZ-GE VVT-i (measured CR 8.07:1)
o Cylinder block (original)
- bored and honed for Wiseco forget pistons 87mm (clearance 0.09mm)
- 2JZ-GTE oil-squirters (drilled 8mm front oil gallery)
- painted in silver
- Wiseco forget piston kit 87mm (350 +/-1 g)
- CARRILLO PRO-H Heavy Duty Rods w/ CARR bolts (600 +/-1 g)
- ACL crank and rods bearings (std size)
- original crankshaft
- ACL main studs
- ATI Super Damper, dry sump (by Twins Turbo)
o Cylinder head (original)
- intake & exhaust porting
- cleaned all roughnesses in chambers
- polished exhaust ports and chambers
- polished surface for headgasket (0.05mm)
- Ferrea bronse valve guides
- Ferrea valves (std)
- Ferrea valve seals & locks
- Brian Crower valve springs
- Brian Crower titanium retainers
- Toyota MR-2 shimless buckets (by Twins Turbo)
- Brian Crower camshafts 264*
- HKS head gasket 2mm x 88mm
- ARP head studs (220.000 psi)
- New Toyota VVT-i pulley
- HKS exhaust cam gear
- HKS timing belt
- Toyota 2JZ-GTE non-VVT-i coil brackets with ARP bolts
- Toyota 2JZ-GTE VVT-i valve covers
- one exhaust side fastening moved for 2JZ-GE head
- PCV outlet removed and -12AN fitting welded
- painted in red (up to 700 *С)
- ARP bolts (by Twins Turbo)
- Toyota 2JZ-GTE VVT-i spark plug cover
- painted in silver
- Lexus emblem
o Cooling system
- C-ONE cold thermostat (68*C)
- MEZIERE electric water pump (20 GPM, 6.5A)
- KOYO aluminum radiator (36mm for IS300 mt)
- WEAPON-R aluminum coolant reserve tank
- Flex-a-lite 392 radiator fans (2 x 12", 1850 cfm, 15.4 A)
- air conditioning pump removed
o Lubrication system
- Twins Turbo 2JZGTE dry sump kit (stage 5, oil pan mod for GS300)
- Twins Turbo dry sump tank (2.5 gallons)
- Brown and Miller 5 stage dry sump plumbing kit (by Twins Turbo)
- factory oil cooler removed
- oil filter relocated
- BLITZ sensors oil filter sandwich
- TRD Sport oil filter
- Perma-Cool hydraulic thermostat
- B&M 70297 cooler w/ fan & electronic thermostat
- Brown and Miller fittings & hoses (by Twins Turbo)
o Crankcase ventilation system
- provided through dry sump system tank
- Brown and Miller fittings & hoses -12AN (by Twins Turbo)
- Twins Turbo breather tank with internal baffles
o Intake
- JUN-style intake manifold for 2JZ-GE
- 100mm throttle body
- VirtualWorks throttle cable
- AEM water-methanol injection system
- Synapse synchronic blow-off (close to throttle body, discharge to turbo's inlet)
- Synapse boost connect kit (low temp)
- Turbonetics intercooler (800x600x75, before - 2.5" piping, after - 3" piping)
- K&N air filter 100mm
o Exhaust
- SOARA TwinScroll T4 Turbo Manifold (long runners, 2 gate outlets)
- SOARA 3" downpipe (V-band clamps)
- BLITZ Nur Spec R exhaust
- Garrett GT3788R TwinScroll T4 turbo (cold a/r 0.7, anti-surge housing, hot a/r 0.99)
- Inconel TwinScroll T4 turbo gasket (by Twins Turbo)
- 2x Synapse synchronic 50mm wastegates (dischage under engine)
- Synapse boost connect kit (high temp)
- Brown and Miller -12AN oil drain line (by Twins Turbo)
- -4AN braided steel oil feed line (0.9 mm restrictor)
- Summit Racing -6AN water cooling lines (for turbo)
o Fuel system
- Walbro 255 lph (GSS342) pump in tank w/o filter & fpr (feed to fuel collector tank)
- PHR fuel pump hanger with -6AN fittings (return from fuel collector tank)
- SARD 5L fuel collector tank in trank
- 2x Denso 280 lph pumps (195130-1270) in the fuel collector tank
- Summit Racing 2 braided steel -6AN feed lines & -6AN return line
- 2x Aeromotive fuel filters (10 micron)
- PHR High Performance fuel rail (17mm ID, -6AN fittings)
- Aeromotive 1000 fuel pressure regulator
- RC Engineering top mount peak & hold injectors 1000сс (+/-1cc)
- AEM peak & hold injectors driver (10 channel)
- 2x Aeromotive 16306 fuel pump speed controllers
o Ignition system (COP CDI)
- 2x AEM Coil Drivers (30-2840)
- AEM TwinFire (C2DI) 8 channel ignition (30-2820)
- 6x SuperSpark COP for 2JZGTE
- New Toyota 2JZGTE COP connectors, switched harness CDI / DIS
- Denso Iridium Racing IK24-01 spark plugs
o Engine management
- AEM EMS (30-1050, v1.19b)
- AEM 3.5 & 5 bar pressure & AIT sensors (MAP, MAT, back pressure)
- AEM wideband inline controller w/ sensor
- 2x AEM EGT sensors (RTD-type)
- BLITZ SBC i-Color Spec R (BLITZ sensors, wideband, egt)
- BLITZ fuel & oil pressure and oil temp sensors
- APEXI turbo timer
o Custom 200А alternator
• Transmission
o Import Performance Transmissions fully rebuilded A650E A/T
o Import Performance Transmissions high stall torque converter
o CUSCO LSD 1.5way RS-type
o B&M 70297 ATF-cooler with fans & electric thermostat
o Perma-Cool hydraulic thermostat
o SummitRacing -8AN hoses & fittings
o A/T management
- Lexus factory ECM
- Split Second PSC1-003 as MAF-emulator
• Brakes
o JBT 355mm x 32mm slotted rotors (front & rear)
o JBT forget 6-pot calipers (front) & 4-pot calipers (rear)
o JBT street racing brake pads (0-650 *С)
o JBT braided steel brake lines
o 2x Titan Motorsport line-lock kits (left & right channels)
• Suspension
o TEIN Flex coilovers
o TEIN EDFC
• Body (xeralic RED)
o TEIN front & rear performance bars
o VARIS carbon-kevlar vent hood (RED)
o AEROCATCH hood lockers with keys (RED)
o Custom Lexus emblem set (RED)
o full around LED optics
o full around black film toning
• Wheels
o RAYS TRD PREMIUM 19" rims, 8.5J front, 9.5J rear (street)
o Michelin PS2 tires 235/45 front, 265/35 rear (street)
o Tanabe SSR Professor SP1 18"x11 (SBC) rims rear (drag strip)
o HOOSIER Drag Radial 315/30-R18 tires rear (drag strip)
o TRD lock nuts (RED)
o RAYS Forula 1 lock nuts (RED)
o H&R spacers (front)
• Power electrics
o OPTIMA RED battery
o TAYLOR battery relocation kit
o TAYLOR 0/1Ga cuprum wires
o SUN hyper voltage stabilizer (RED)
o SUN hyper grounding kit
o Separate 0/1 Ga wire for a starter
o 2x ARC 4-button control panels
o Stinger 200A circuit breaker
o relay blocks, distributors, wires, e.t.c. (Stinger, Summit Racing)
• Electronics
o Embedded PC, Atom 1.6 Gz, Windows XP (AEM Pro, video/music)
o Xenarc monitor 7" VGA + DVD + USB-hub (1 DIN)
o BLITZ R-VIT DS (VGA output - up to 32 channels OBDII)
o Innovate OT-1 (OBDII scanner)
o APEXI RSM w/ G-sensor
o StreetGlow OPTX LED Wheel Well Lights (multicolor)
o LED seat lights kit (RED)
• Cool gadgets
o Ferrari RED leather gloves
- painted in silver
- ACL main studs
- HKS timing belt
- painted in silver
- Lexus emblem
o Cooling system
o Intake
o Exhaust
o Fuel system
o Engine management
- APEXI turbo timer
• Transmission
o A/T management
- Lexus factory ECM
• Brakes
• Suspension
o TEIN EDFC
• Wheels
• Power electrics
• Electronics
• Cool gadgets
