Supra LSD Question....
Old Jul 1, 2007 | 02:47 PM
kilawatts's Avatar
kilawatts
Arrow Supra LSD Question....
I have been offered to trade my stock GS400 3.26 Rear End for a 4.27 pumpkin with lsd from a NA MKIV supra. I am not certain why someone would want to make this trade seeing as my Rear End is not LSD, but not complaining seeing as I want an LSD.
My question is this.... will this bolt up and perform well? I notice the majority is using the 3.76 LSD. Is 4.27 too high of a ratio for a GS400? I do not have a TC, but it will most likely be my next mod. Any advise would be greatly appreciated.
Old Jul 1, 2007 | 02:55 PM
GS FONZy's Avatar
GS FONZy
that is high, but if you want low end power, that gear ratio would do it. you don't even need a tc with that kind of gearing.
are you swapping the whole diff assembly of just the guts?
Old Jul 1, 2007 | 02:59 PM
kilawatts's Avatar
kilawatts
It would be the whole diff assembly. That would be awesome if I didn't need the TC. What do you think it would do with both?
Old Jul 1, 2007 | 03:04 PM
Lexamatic's Avatar
Lexamatic
4.27 w/LSD may be hard on the stock tranny, U-joints & CV-joints.
Old Jul 1, 2007 | 03:12 PM
GSteg's Avatar
GSteg
putting on a 4.27 differential would basically be equivalent to having 405ftlbs of torque (at the crank) with the 3.26. No doubt you'll launch harder, but you will have trouble with traction. Not to mention, you're going to be sucking up so much gas since your engine will be revving high most of the time.
I believe lexism has a 3.92 gearing on his GS430 and he's able to spin his 20s off the line. Even 3.92 is a bit extreme.
Old Jul 1, 2007 | 07:12 PM
kilawatts's Avatar
kilawatts
Do know if Lexism is having any tranny or joint problems? I don't mind the gas because I drive a short distance each day. But being a daily driver I am not trying to kill my GS either.
Thanks for all the imput guys... It is greatly appreciated!
Old Jul 1, 2007 | 07:39 PM
GSteg's Avatar
GSteg
He doesn't have any trouble.
You wont have any problem unless you floor your car all the time. Then again, if you do that, your tranny is expected to go anyways, regardless of the gear ratio.
Old Jul 1, 2007 | 08:02 PM
GS FONZy's Avatar
GS FONZy
TC makes you launch harder, but that gearing would be enough. having a TC would be overkill and add stress to your tranny. IMO
you will see a big diffrence in highway driving. your RPMs will be a lot higher than what they are now for highway speeds. if you say you only drive street short distance, than you should be ok. if i were you i would invest in a tranny cooler.
good luck and keep us posted
LEXSOOS
Performance
19
Oct 30, 2006 10:03 PM
LasVegasGS
Performance
21
Jul 28, 2005 07:42 PM
lex400sc
Oct 28, 2004 03:13 PM
CJGS4
Performance
Apr 24, 2004 07:59 AM
