Official Tranny Cooler Thread for the 2GS
What you doing vince? rods/pistons?
jesus i dont even know if i have them....have to check my invoices....plus a few were made for my by a member 99 gs3 in this thread
https://www.clublexus.com/forums/per...ded-lines.html
its coming..... all fittings assembled with teflon tape, all lines now put together, 2 cases (24 quarts) of tranny fluid has arrived. getting on my buddies rack next week and getting these all installed
OOPS,maybe he meant just to teflon the threads from the A.N. fittings to the NON-A.N. threads. no biggie i can easily undo the teflon
alright so i started working on this but only got so far as i couldn't remove the OEM tranny fittings from the tranny while it's installed....well i didn't have the correct tool to do this. any tips/thoughts/suggested tools to remove these while the tranny is still installed?
ALSO if anyone needs to know the line I'm pointing to in the picture is the line pumping fluid from the tranny to the OEM cooler, if your gonna hook up a external remote mount filter you need to know which one is which....
Sir what is pictured above is a engine oil cooler.....hence the filter adapter.....if you are using the cooler for a tranny you don't need half of what is pictured....sounds like you were severly misinformed
yeah what is pictured above (my picture on post # 158) DEF isnt a engine oil cooler (where do you see a filter adaptor?) so maybe its just YOU dont know what your talking about or your just not clarifying well enough WHICH picture you mean. its my alternator and my sway bar with lines run to drain my OEM lines coming from the transmission...although you ARE right about one thing, i DONT need half of it, its kind of overkill for my next project which WILL need it
u have now been added to my ignore list.....
You won't see this if indeed I have been added to your ignore list but I would encourage anyone interested in knowing how all of this got started to look at my original post. I simply suggested that he was misinformed.....thats not saying he is stupid or dumb and didnt insinuate anything other than maybe he had been told incorrectly....his following post said...in caps....that I did not know what I was talking about....
After all of this...look at his last post....than look at pic in post 158...is he not pointing at what appears to be the rubber line attached to the hard lines? I will let you all be the judge....good luck in your project my friend.
I btw....I love the vid link....classic!
im gonna end up re-routing this to go from the OEM cooler to the aftermarket cooler and back to the tranny instead of how i had it routed since the tranny should said this would be best for cooling but this is the setup i have used
so far this is a list of stuff im using
GODMAN FITTINGS
Quantity Of 6 -06 Straight Hose End Aeroquip Part # 610-06A
Quantity Of 1 90 Degree Male Elbow -06 AN x 3/8 NPT Part #AN822-06-06
Quantity Of 2 -06 Flare x 1/2-20 MIF Part # 2000
Quantity Of 2 Compression x -6 AN Male- Steel Part # 3080S
Quantity Of 1 90 Degree Male AN To MNPT Swivel -06 x 3/8 Part # 335
Quantity Of 2 -06 Flare Union Part # AN815-06
Quantity Of 2 -06 45 Degree Hose End Aeroquip Part # 645-06A
Quantity Of 18" -06 Stainless Steel Braided Hose Part # FBA0600
Quantity Of 10 9/16 x 9/16 Separators (Fab-0600) Part # 2928
Quantity Of 10 5/8 Adel Clamp Part # 2582
the last 2 in blue you can use either or....i like the separators better than the clamps though they look 100% better
JEGS Fittings
Quantity Of 2 (1 Pack) -06 AN Tube Nuts Part # 555-100382
Quantity Of 2 (1 Pack) -06 AN Tube Sleeves Part # 555-100392
RUSSELL FITTINGS
Quantity OF 2 -06 AN Male To 14mm X 1.5 Metric Male Adaptor Part #799-670520
OEM FITTINGS
Quantity Of 1 Nut, Flare (For ATM Oil Cooler) Part # 1649550020
Quantity Of 1 Inlet Sub-Assy Part # 1649774760
Quantity Of 2 OEM Toyota Tranny Fitting O-Rings Part # 9030111006
OTHER PARTS
Quantity Of 1 Vise Jaw Inserts-Aluminum Part # 25251
Replacing all the hard lines in here from the transmission to the OEM cooler
http://lexus.sewellparts.com/oem-cat...S430-2001.html
GODMAN FITTINGS
JEGS Fittings
RUSSELL FITTINGS
OEM FITTINGS
OTHER PARTS
