Consistent p2241 cel that won’t go away PPE headers?
Old Oct 10, 2023 | 03:48 PM
mangocat97's Avatar
mangocat97
10th Gear
Default Consistent p2241 cel that won’t go away PPE headers?
So for context I’m pretty new when it comes to Lexus’s jsut got my 2007 is350 a couple months ago and for all the random issues I’ve had with it I still love it, but my main focus rn is my CEL that that will not go away my car does have PPE header and a HKS axle back im assuming my issue is having to do something with the de catted headers however once I got under the brand new 02 sensor’s connector was melted and had exposed pins inside the connecter I assumed this was my issue so instead of wasting the brand new denso 02 sensor I snipped the wires and spliced the new connector onto it, my cel is still here even after I disconnected the battery, could the 02 sensor it’s self be bad from being shorted? Should I try the eBay 02 sensor I got to replace it? It has a base map on it as well from the previous owner. I also notice that my mpg is pretty bad, I mean I’ve never seen it go over 18mpg
Old Oct 11, 2023 | 12:49 AM
Idkyet2is's Avatar
Idkyet2is
My O2 wire extender melted as well and I got the same code.You also have to replace the A/F fuse located under the hood on the driver's side.
Old Oct 11, 2023 | 07:33 AM
mangocat97's Avatar
mangocat97
10th Gear
the af fuse looks fine I switched fuses around and it’s still there
Old Oct 11, 2023 | 07:41 AM
Idkyet2is's Avatar
Idkyet2is
Really? The fuse didn't blow? Have you tested your relay as well?
Old Oct 11, 2023 | 08:11 AM
MikeFig82's Avatar
MikeFig82
I'm assuming since it's involving the Emission System. It may have thrown a permanent code.
It won't clear the CE Light untill it's remedied. Even if you disconnect the battery.
https://www.bar.ca.gov/industry/pdtc...20scan%20tool.
I thought you needed O2 foulers for post cats? with headers?
On RR's website I think they're available for purchase.
Old Oct 11, 2023 | 08:41 AM
mangocat97's Avatar
mangocat97
10th Gear
No I haven’t what relay is it and how would I check it? Also the fuse had a bit of corrosion so I’ll replace it anyway
Old Oct 11, 2023 | 08:43 AM
mangocat97's Avatar
mangocat97
10th Gear
I’ve read about the O2 spacers are those similar?
Old Oct 11, 2023 | 08:55 AM
MikeFig82's Avatar
MikeFig82
Yes, but not all work. You'll probably have to find a good set.
Here's some threads to look at.
https://www.clublexus.com/forums/per...-question.html
https://www.clublexus.com/forums/is-...g-cel-fix.html
https://www.clublexus.com/forums/is-...d-o2-sims.html
Old Oct 11, 2023 | 11:59 AM
PPEHeaders's Avatar
PPEHeaders
Sponsor
Hi,
That code P2241 is for the heater circuit in the Bank 2 (Driver's side) Sensor 1 (upstream A/F sensor in the header).
You can check your sensor's heater circuit by measuring the resistance between the two black wires. It should be between 15-25 ohms. If it is zero, then the sensor is bad.
If it reads correctly, there may be an open circuit in the black wires in the extension harness.
I would not use any other brand of sensor other than DENSO or from the dealer (Made by DENSO). Other brands can cause a CEL.
Old Oct 11, 2023 | 08:49 PM
jgscott's Avatar
jgscott
We just talked about this here also. I said the same thing.
https://www.clublexus.com/forums/per...l#post11592089
Old Oct 12, 2023 | 05:57 PM
mangocat97's Avatar
mangocat97
10th Gear
I jsut took the old 02 sensor out and it was completely black just so dirty, could this have been part of the issue??
Old Oct 13, 2023 | 08:19 AM
MikeFig82's Avatar
MikeFig82
It sounds like it's fouled up. What does does your fuel trims look like?
Old Oct 13, 2023 | 07:04 PM
PPEHeaders's Avatar
PPEHeaders
Sponsor
that code is electrical only. based only on the current passing through the black wires/sensor
jgscott
Performance
Aug 25, 2021 06:35 AM
MDHLexus
Performance
Aug 15, 2016 11:19 PM
MurdaInc
Nov 2, 2015 12:46 PM
MrPhung
Performance
25
Mar 23, 2012 05:23 PM
tomtsops
Performance
Feb 7, 2011 04:15 PM
