NX - 2nd Gen (2022-current)
Random Clock Times
Old Mar 30, 2022 | 04:45 PM
JPB23's Avatar
JPB23
Default Random Clock Times
A new issue in the infotainment system the last couple of days. Each time I start the vehicle, the clock is showing hours in difference from the actual time. After resetting the clock in the systems, the same thing happens after I restart the vehicle. The software update cannot come soon enough.
Old Mar 30, 2022 | 05:54 PM
BC310's Avatar
BC310
Maybe the car is confused about which time zone it's in. Have you tried switching from Set Time Automatically to Set Time Manually? Of course, it would be better for the car to figure it out, but unless you're frequently crossing time zones, leaving it fixed on manual might be enough.
Also, which profile is loaded when you do this? The auto/manual setting might be tied to the profile.
Old Mar 30, 2022 | 06:20 PM
JPB23's Avatar
JPB23
It was set to automatically. This afternoon it said I was in Hawaii's time zone, but I live in MA. My profile doesn't connect automatically unless I type in my pin. I don't even bother and just leave it as guest.
Old Mar 30, 2022 | 06:24 PM
midcow3's Avatar
midcow3
Talking
Move to Hawaii ... problem solved
Old Mar 30, 2022 | 06:30 PM
JPB23's Avatar
JPB23
Go ahead, make your jokes, Mr. Jokey... joke-maker. But let me hit you with some knowledge. Quit now. Save yourself the embarrassment of losing with these losers in Las Vegas, La Fleur.
Old Mar 30, 2022 | 06:50 PM
BC310's Avatar
BC310
This is probably the bigger issue you should have your dealer look at too. We need Lexus corporate to know it's NOT ok that the new Lexus Interface is so buggy.
Old Mar 30, 2022 | 06:53 PM
JPB23's Avatar
JPB23
You are correct! These glitches should not happen.
Old Mar 30, 2022 | 08:44 PM
midcow3's Avatar
midcow3
Question Did you apply software update ?
If you have read this forum you would know there are a lot of minor software problems with profiles and different keys being used. A recent software update was issued which fixes most of the problems. Did you apply the software update from Lexus ?
Old Mar 31, 2022 | 05:41 AM
JPB23's Avatar
JPB23
Yes, I have read this forum. That is what this forum is for to share your thoughts and concerns. This was a new issue that I hadn’t seen anyone else report. I am in the middle of my update right now. If it solves the many issues which people have reported, I won’t have anything left for this forum.
Old Mar 31, 2022 | 11:32 AM
ct6978's Avatar
ct6978
We've seen the clock reset a bunch of times, once twice in a day. I've tried manually setting, set by GPS, or set automatically, nothing seems to stick. In addition to the Hawaii time zone shift, we also get some random times showing up, so possibly a few flavors of the issue.
Theoretically in the patch that's just starting to roll out (randomly by VIN evidently, but some folks here have gotten it) there's a fix for part of the issue. Here's how its worded in the bulletin:
"Daylight savings time intermittently turns OFF"
My dealer has also told me the Time Zone switch to Hawaii is known, but not sure if the fix is in the patch. They suggested sticking with 'Set Time by GPS" as the best choice.
ScytheDC
Apr 28, 2025 04:55 AM
hwtharpe
Jul 15, 2020 09:58 AM
Acrad
GX - 2nd Gen (2010-2023)
Feb 21, 2019 03:04 PM
HenryNYC
RX - 4th Gen (2016-2022)
Mar 6, 2018 11:20 AM
