NX - 2nd Gen (2022-current)
Level 2 Charger
Old Aug 1, 2023 | 08:19 AM
chuckles1313's Avatar
chuckles1313
3rd Gear
Default Level 2 Charger
Hey guys new to the forum but just ordered a 2024 NX 450h+ expected to get here by the ned of August! We want to do a level 2 charger and am curious what people have done or recommend for that. I had a 30amp 240 V circuit wired in my garage already but after reading it sounds like you really need a 40amp circuit to get the maximize charge speeds the car can do. One of the reasons we went with this particular car is we have 4 kids and do two shifts of daily driving (morning and afternoon) so will want to charge as much as possible in between those two shifts.
Old Aug 1, 2023 | 09:37 AM
nx450plus's Avatar
nx450plus
The 6.6 kw charger can use up to 40 amps as you correctly mentioned. I don't have level 2 at home since I use free public level 2 and sometimes level 1 at home.
Old Aug 1, 2023 | 10:13 AM
drox's Avatar
drox
Using the 80% rule, you should only pull 24A from that circuit at 240V which is 5.76kW. After considering some losses in the EVSE you will be charging the car at about 80% its maximum.
So my recommendation would be to get an EVSE that supports at least 40A and can be configured to be 30A for now. Try it out with your existing plug and if you want a bit of extra charging speed, pay an electrician to upgrade your circuit.
It's also not terrible to run out of EV charge and run your engine once in a while. It's a hybrid, not an EV.
Old Aug 3, 2023 | 06:18 AM
NSXT's Avatar
NSXT
I have installed a 50A instead of 40A as the 450h+ draws 32A and a bit of future proof for the next one.
Going from 12 hours lvl1 to 2.5 hours is a huge time saving
I have installed this: https://grizzl-e.com/product-category/canada/
Old Aug 3, 2023 | 06:40 PM
SgtLip's Avatar
SgtLip
@chuckles1313 Okay, I was thinking about this same thing once I accepted the deal on my 450H+ back in early March this year. It was exactly a month until I picked up my car. I know absolutely nothing about electricity but my son is an Electrical Engineer working on the new launch pad at NASA in Cape Canaveral. So I asked him this question and he provided a response.
Question:
Home power source
Charging voltage: AC 120 V
Charging current: 12 A
Estimated charging time: Approximately 12 hours
VERSUS
AC charger (vehicles with 7 kW onboard traction battery charger*)
Charging voltage: AC 240 V
Charging current: 32 A
Estimated charging time: Approximately 2 hours 30 minutes
Does one use more power than the other? Which is cheaper? Just curious. Would you use the 120V for 12 hours or the 240V for 2.5 hours?
His Response:
All else being equal, the 240 volt circuit would consume about 11% more total energy, per charge.
But the 120 volt circuit charge time is 400% longer.
But if you don't EVER expect to need to charge quickly, I'd go with 120.
I just know that the first time I want to GO, but have to wait 12 hours, I'ma wish I had the 240.
I went with the 240V. I have the ChargePoint and hardwired it to the Electric Panel. I also purchased and connected the 60 Amp version. My electric provider is a Co-Op Company so they do note offer any lower amounts for EV charging overnight. So I pay the same rate 24/7/365 so I charge it up as soon as I get home that way it's ready to go.
Hope this helps.
Old Aug 5, 2023 | 02:43 PM
chuckles1313
3rd Gear
Thanks that was helpful. After reviewing everything I will probably install a new 40a or 50a circuit dedicated for this as the old outlet could be used by power tools in the garage still.
Old Aug 7, 2023 | 08:17 AM
Uspeed's Avatar
Uspeed
I got Autel from amazon very nice works well, did 40amp
Amazon Amazon
I got for 450, this comes on sell, so keep eye.
Old Aug 7, 2023 | 08:28 AM
chuckles1313
3rd Gear
Yep I ended up going with 40 amp circuit (I was not worried about future proofing and needing 50 amps) and I got the Autel off amazon after watching this review:
CobraGSF
GS F (2016-present)
13
Oct 21, 2020 01:38 PM
2jzali
IS - 1st Gen (2001-2005)
Oct 23, 2019 07:44 AM
01a4man
Sep 7, 2009 11:52 PM
beaterKU
Jun 11, 2007 09:54 PM
