NX - 2nd Gen (2022-current)
Subwoofer
Old Sep 4, 2024 | 09:50 AM
  #301
tdlnfm's Avatar
tdlnfm
Originally Posted by Electric65
I plan on installing the JL Audio C2’s for corner dash speakers within the next few days. Before you did the center dash speaker, did you feel the need to attenuate it via a resistor like some other posters have done? How much did swapping center stock for JL help?
Something was very much misunderstood. Previously #Atomiclexus recommended the series resistance only for the stock center speaker in order to quiet down that horrible distorted factory sound. In the case of updating with a quality speaker, there is no reason for resistor.
Old Sep 4, 2024 | 10:14 AM
  #302
Electric65's Avatar
Electric65
Originally Posted by gompka
The center is messed with by the stock system, there is eq and time alignment stuff going on there. So just unplugging it while using upgraded dash speakers makes the sound worse imho, I tried attenuating it, and don't really see a benefit. I just left it stock and plugged in and it seems to work well with the upgraded dash speakers. In a perfect world I would replace the stock stuff to have full control over the sound, but don't want to get into all that complexity and cost. The dash speaker upgrade alone was great. I managed to cram 4" image dynamics full range speakers into the stock dash locations.
Interesting. What model speakers did u buy?
Old Sep 4, 2024 | 06:23 PM
  #303
Electric65's Avatar
Electric65
Yep, I understand. I was asking if he felt the need to attenuate the stock speaker before he then upgraded it to JL Audio, or if he never even tried adding a resistor and instead went straight to the JL Audio.
Old Sep 4, 2024 | 10:03 PM
  #304
midcow3's Avatar
midcow3
Lightbulb Center Speaker Woahs
If you look at post #1 @AtomicLexus says "Many change the center speaker too, and you think that it would sound better, it generally does not. The “surround sound” that Lexus-Pioneer uses is junk, and the best way is to simply throttle the volume of the center with a simple 2-ohm 5-watt resister in line from the positive wire to the speaker. Use the extra adapter. You can also just disconnect the center. If you insist on replacing it with a match to the side, I would still add the resister in line."
If you aren't planning on spending really big bucks to replace that OEM Lexus-Pioneer audio head and add amps, harnesses, steering wheel controls, filters, equalizers, and such, it appears there is little hope for good sound from the center speaker, SORRY.
Peace and Good Sound...as best as possible that you feel you can cost justify
YMMV,
MidCow3
Old Sep 4, 2024 | 11:36 PM
  #305
Lexicon1's Avatar
Lexicon1
Electric65, I followed tdlnfm's lead and advice and used the JL- C2 350x family of speakers in the dash , I did not add a resistor. As tdlfn indicated, if using the JL models, you do NOT need a resistor. The system sounds great. Re-read my posting above regarding taking advice from those who have actually done the installation and with the model speaker you are considering.. As tdlnfm indicated very many posts back, you will not be disappointed...... If you are on a budget, just go w the less expensive speakers others have used.Nothing wrong w that.
Old Sep 5, 2024 | 12:39 AM
  #306
tdlnfm's Avatar
tdlnfm
Sorry, I misunderstood then. I didn't experiment with the factory center, I just replaced it.
Note, I think JL C2 is overkill for this position, unless you team up with someone and so it's half price. (In the case of music the sound image in 95-99% is determined by the corner speakers, the doors and the sub together. Center has significance is really only for speech and navigation).
Old Sep 5, 2024 | 10:51 AM
  #307
midcow3's Avatar
midcow3
Lightbulb Clarity ...if possible ;)
YMMV,
MidCow3
A little Clarity, in a way both @AtomicLexus and @tdlnfm both make good points. With the factory audio Lexus -Pioneer head the center speaker won't sound great. Putting a resistor reduces the volume significantly via power =i*r^2. And as said by @tdlnfm the center speaker is primarily for voice: Prompts, navigation, telephone, speech, etc. However, in any case whether you attenuate the center speaker or not, if you replace it with a better speaker, you will get better sound.
speakers
Again, the easiest two upgrades to improve your sound systems are (1) replacing the front speakers ( mainly discussion has been front deck, but front door speakers are also key speakers) and (2) replacing subwoofer with a powered subwoofer. Replacing the center front speaker, good move if you listen primarily to talk radio/XM
YMMV,
MidCow3
P.S.- Disclosure: I have ML system in my NX 350h so I did not upgrade this car. However, in the past I have upgraded many cars and home sound systems; a little experience here and there along with a little understanding from BSEE and being a long-time member of Audioholics.
Old Sep 5, 2024 | 04:50 PM
  #308
CJLane's Avatar
CJLane
5th Gear
speakers
YMMV,
MidCow3
This is basically it. And to answer someone's earlier question..no I just upgraded the left and right dash. I did not do the resistor thing and it was a dramatic improvement just doing that. You'll still notice alot of voice coming from the center but the sound doesn't sound like it's coming through a tin can anymore with just the two dash upgrades. I'm just overzealous and I upgraded my center..and it was a barely perceivable change to the sound, so if you don't want to splurge like me...just the two dashes will do wonders at minimum. Add the sub (or amp the stock one) to fix your bass.
Old Sep 6, 2024 | 04:26 PM
  #309
MoNX350's Avatar
MoNX350
Hi @tundotcom did you get a chacne to do this? And do you have a guide on how to do so? I want to do the fios amp but not sure how to do it. Would love to fix the bass in my car - did the two dash speakers already... Any help would be great please
@AtomicLexus
Originally Posted by tundotcom
Installed my Infinity Reference REF-3032CFX speakers today. Thanks to @Droid13 @SgtLip @AtomicLexus and others for their help. Getting the speaker grilles off was the hardest part for me. The passenger side one in particular is hindered by the A pillar cover, so I really had to yank it out. I ended up leaving a mark on the A pillar fabric on both sides but I don't care too much about that.
The rest of the installation was pretty easy. All the advice was spot on. 10mm combination wrench to crack the screws loose and carefully remove by hand. Metra 72-8109 is indeed the correct cable. The black and white ends are different sizes so there should be no mistaking where to clip them onto the speaker end. Inserting the screws at a 45 degree angle at first and then slowly tightening them down worked like a charm.
If you're a complete newbie like me, you can definitely do it on your own with the information in this thread. The speakers sound much better than the OEM Pioneer speakers but as mentioned before, the weak bass is definitely more noticeable now.
The last part for the subwoofer amp install from AliExpress arrives today, but now I need to wait for one of you guys to take pics of the entire process before I attempt it on my own.
edit: everything has arrived. Anything I am missing?
Old Sep 6, 2024 | 05:50 PM
  #310
tundotcom's Avatar
tundotcom
@AtomicLexus
Nope, I was also waiting for someone to write up a guide. All those parts have just been sitting in a box gathering dust lol. I literally have no idea what to do and what tools I would need.
Old Sep 6, 2024 | 08:22 PM
  #311
MoNX350's Avatar
MoNX350
LOL - Damn that sucks - I hope someone comes to our rescue - do you mind at least letting me know all the parts that I need for this project? This thread is so intense lol
Old Sep 10, 2024 | 10:11 AM
  #312
Electric65's Avatar
Electric65
Swapped in JL Audio C2-350x for the dash corner speakers and the sound is much better than stock. Thanks @AtomicLexus for the recommendation!
However, when the Lexus “surround” setting is turned on, the stock dash center speaker seems to be putting out more and overtaking the upgraded corners. Not an issue with surround turned off, since that speaker doesn’t seem to get used then. But I kind of like the enveloping effect more with surround turned on.
In this case, with surround turned on, I’m assuming upgrading the center to also use a JL Audio C2-350x would actually have a decent impact since it’s being used for the music and not just phone voice/nav? @AtomicLexus are you able to confirm?
Also... anyone with an NX350/450/h who has swapped out their speakers (and/or done the sub amp upgrade) know what kind of effect we're having on the Active Noise Cancellation (ANC)? Are these enhancements going to make that feature better or worse? Note I turned OFF the Engine Sound Enhancement (ESE), which is the fake engine noise that plays through the speakers.
Old Sep 10, 2024 | 06:53 PM
  #313
CJLane's Avatar
CJLane
5th Gear
I did the center swap..it’s a barely perceptible improvement. Seriously…it seems counterintuitive to say that but that was my impression. I’m not an expert but if I can describe it the loudness of the audio from the center channel barely sounded different with a better speaker.
Clearly not the case with the sides. But if you really want to scratch the itch it won’t hurt. I may even recommend using a cheaper set for the center than the JL if u do.You won’t really be taking advantage of the JL’s capabilities. But having said that..there are people like me who insisted on all 3 matching..lol.
Old Sep 10, 2024 | 07:14 PM
  #314
Electric65's Avatar
Electric65
Haha gotcha. I’m no expert either To confirm, do you usually listen to music with the “surround” mode on or off?
Old Sep 10, 2024 | 10:52 PM
  #315
fierymonkey's Avatar
fierymonkey
how do you turn off the ese? Where do you find the options. Thanks
