Navi Map Update
I have a 2016 NX with the original 2015 maps and don't mind spending a little money to get current but that just seems outrageous.
https://gromaudio.com/installs/lexus...ce---demo.html
What you probably want to do is to purchase the NAVI microSD card at the dealer only and not have them install it. If it's microSD card, it should be pretty easy setup. The dealer should know which microSD Card you will need for your vehicle. Swap the miscroSD card with the vehicle off, then turn on and do the update. It may take 5-10 minutes. Check if you have this on your vehicle first.
I used to have a 2006 Rx400h, and finding and replacing the navigation CD is the same for the all the older Rx models.
Turn on the ignition, open the rear hatch, pull back the floor mat, open the floor storage area lid, and you'll find the CD slot in the forward/right area of the lower storage area. With the ignition on (and standing on your head), slide the switch to the left (toward the front of the car) and eject the CD.
After replacing the CD with a new one, slide the switch aft, close the cover, close the hatch, turn off the ignition, and you're done.
As I recall, the new CD cost around $100USD in 2012, and the dealer wanted another $100 to install it...
