question regarding spark plug change
Old Aug 11, 2009 | 11:29 AM
vwynn's Avatar
vwynn
Default question regarding spark plug change
i was wondering would it be best to change the plugs when i do my timingbelt/waterpump or it doesnt matter when i hold off?? i currently have the colder plugs on standby under my desk. yea i know.. silly question
Old Aug 11, 2009 | 12:21 PM
iSuxeL's Avatar
iSuxeL
I wouldn't wait personally.
Old Aug 11, 2009 | 05:43 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
How many miles are on your car?
Old Aug 12, 2009 | 08:43 AM
vwynn's Avatar
vwynn
currently have 144k miles
current spark plugs... ApexI iridiums
also side question... what parts do i need for timing belt change?
so far..
timing belt
serpentine belt
water pump
timing belt tensioner
pully (which?)
2x bottles of toyota red.
cam seals? (heard its a PITA and could leak if done impropperly)
and what else?
Old Aug 12, 2009 | 09:55 AM
GSteg's Avatar
GSteg
You can do it now if you want. The procedure for changing spark plugs has almost nothing in common with a TB/WP change. It's just a matter of getting the engine cover off and taking out the coil packs.
Old Aug 12, 2009 | 10:47 AM
AlexusAnja's Avatar
AlexusAnja
So you have 144K on the original belts? Nice gambler you are...
The two are not related, so unless you just don't want to open your hood up twice, I would do the belts first and then tackle the plugs afterwards.
Old Aug 12, 2009 | 01:08 PM
vwynn's Avatar
vwynn
supposibly the belt has been changed at 90k miles. or so the seller said... but then again the seller didnt mention anything about frame damage... or leaky supercharger haha
Old Aug 12, 2009 | 06:04 PM
RTIS250's Avatar
RTIS250
CL Folding 500,000
I would strongly recommend against doing the cam seals yourself, if you arent comfortable removing the camshafts. Replacement of those cam seals requires removal of the VVTi cam gears and camshafts.. not an easy job.
Old Aug 16, 2009 | 06:48 PM
vwynn's Avatar
vwynn
update: changed the plugs and i gotta say it feels so much better tho
the old plugs were nice n dark... n not really efficient.
also changed the outer tie rod n tightened the daizen sways.. no more clunks! more moving on to the bigger job.. timing belt stuff.
Old Aug 16, 2009 | 08:13 PM
GS4_Fiend's Avatar
GS4_Fiend
The timing belt lasts up to 130k on our cars, IME. As for spark plugs, why not go with the Denso Long Life? They last 100k and they are OEM.
Old Aug 17, 2009 | 07:10 PM
vwynn's Avatar
vwynn
well i decided to get whatever the other boosted guys got n yea. DaveGS recommended theses plugs so i got them.
kpopil
RX - 1st Gen (1999-2003)
Jan 12, 2009 10:03 AM
ynotlex
Mar 25, 2008 05:48 PM
O. L. T.
Sep 6, 2007 10:55 AM
sxwk12
Jun 20, 2005 02:17 PM
GlobeCLK
May 9, 2005 07:27 PM
