LS460: Is This Maintenance Necessary Now?
Old May 31, 2019 | 02:59 PM
jwillis123's Avatar
jwillis123
Default LS460: Is This Maintenance Necessary Now?
I am very lucky to have acquired a 2011 LS460 in December with only 10,000 miles. I had a full-service inspection then and it needed a battery (no surprise) but everything else checked out like a practically new car. Took it in today for a 15K service: LOF, brakes and tires are good; however, the tech is recommending brake fluid; both air filters; differential fluid; coolant flush and a transmission flush. Grand total is $969.00.
My dumb question of the day: Forgetting the high price, do these items need to be done simply because the car is now eight years old despite the low mileage? Being in Arizona, I can understand the coolant and air filters, but the rest surprised me.
Thanks in advance for any feedback from my fellow 460 brothers!
Old May 31, 2019 | 04:15 PM
johnnyg66's Avatar
johnnyg66
Trans flush?? Wow. My dealer wound never say that.
Old May 31, 2019 | 04:48 PM
jwillis123's Avatar
jwillis123
Sounds like air filters are DIY; get the brake fluid and coolant done now and the rest can wait. They cannot see the transmission fluid so this was recommended based on the age of the car.
Owners manual is the size of War and Peace but I'll confirm what the book says. Thanks!
Old May 31, 2019 | 05:20 PM
sktn77a's Avatar
sktn77a
What a phenomenal find! Lucky Bxxxxxx! As others have said, brake fluid every 2 years (hygroscopic), coolant is ready, too (8 years od). I'm surprized he suggested transmission fluid and differential fluid - Lexus consider these "lifetime" and won't change them unless you REALLY kick up a fuss.
$1000 for this work? Find a new mechanic, he thought he'd found an easy touch!
Old May 31, 2019 | 06:20 PM
Vicqlo's Avatar
Vicqlo
My 2011 AWD now has 44k on it. Pristine! Anyway, to date, I have done the following: Front diff, rear diff, transfer case. coolant flush, transmission flush (no issues with shifting), all new brakes (rotors,pads, calipers serviced) new battery and oil changes every 5,000 miles. I plan on keeping it for many more years and believe in preventative maintenance. But, I will say this, when my transmission was serviced at 30k afterwards the shifting was noticeably smoother and very crisp!
Old Jun 1, 2019 | 04:47 AM
mckellyb's Avatar
mckellyb
Here's another vote for brake fluid and coolant, but forget the rest of it. Pull the filters, look at them, and you'll probably put them back for another year, or so.
Consider changing the trans oil at 80K miles, diff around the same time. I'm going to put synthetic in the diff on this car, then not think about it, again.
Old Jun 1, 2019 | 06:51 AM
roadfrog's Avatar
roadfrog
At nearly ten years old, I would not hesitate to change EVERY fluid in my car, REGARDLESS of mileage. Factor in the fact that the low mileage may indicate short trips, which would qualify as severe service by any manufacturer's standard. It would give me peace-of-mind to have a baseline of services done on my schedule and know it was done and when. I agree that the quoted price is off-side though. Changing the coolant and air filters is definitely DIY.
As for transmission "flush". You probably heard wrong and what they meant was a transmission fluid CHANGE. DO NOT do a transmission FLUSH. I do however recommend changing the fluid out.
Old Jun 1, 2019 | 10:51 AM
jwillis123's Avatar
jwillis123
My mistake: it called for changing the fluid due to age not a flush.
Old Jun 1, 2019 | 04:34 PM
sktn77a's Avatar
sktn77a
This is the conventional wisdom for older vehicles with high mileage. The reasoning being that a flush will disturb crud and dirt that has accumulated over the years and miles (and foul up the internal transmission solenoids and switches). For a car with less than 50k miles (or an older one that has been flushed every 30k miles), it probably wouldn't create any problems.
Old Jun 1, 2019 | 06:25 PM
jkittlesen's Avatar
jkittlesen
I did my trans filter and fluid at 72K, fluid was in great shape , so wait no need for you to touch it!
Old Jun 2, 2019 | 08:10 AM
roadfrog's Avatar
roadfrog
Generally, yes, but there are also accounts of issues on new vehicles, depending on the shop and what machine is used. I wouldn't chance it when just doing a drain and fill will replenish the additives etc. I would rather wait and drop the pan and change the filter and replace more fluid later on.
Old Jun 2, 2019 | 10:13 AM
jkittlesen's Avatar
jkittlesen
Originally Posted by FunFact
Where are these accounts of this happening? Please post links to people having these issues on sub 15k mile cars. As long as you ensure they do not use anything other than WS fluids, and that it is not a high-pressure machine, your concerns in a typical fluid exchange are not present.
You suggest a drain and flush because of the age of the fluid, yet your primary concern with ATF age is going to be water contamination and oxidation of fluids. To do a drain and fill is utterly pointless, because you are only removing a tiny fraction of the fluids, which will only serve to rapidly contaminate those new fluids. If you are concerned about contamination of your fluids, you need to remove ALL of it.
A drain and fill will not do that, so either leave the fluid alone or have the full contents removed and replaced.
We have a difference of opinion on this all or nothing approach, I have had no problem through the years doing transmission filter services and not draining all fluid.
Old Jun 2, 2019 | 10:43 AM
Lexus does not advise transmission flushes, so I won’t do them.
I wouldnt do do anything to the fluid right now in this car though.
Old Jun 2, 2019 | 02:11 PM
703's Avatar
703
The only thing you need to do are the filters and a new 12v battery. Everything else is unnecessary.
Old Jun 4, 2019 | 07:32 PM
roadfrog's Avatar
roadfrog
You do have Google, right?
If I was interested enough in this topic, I'd do the work for you (im not in a Lexus anymore). As Steve stated, Lexus doesn't like 'em and that WAS good enough for me.
But I'll give you one little snippet from one of MANY sources:
We don’t recommend it – here’s why:
We have never recommended flushing. Anyone who builds transmissions for a living would never flush their own vehicle. That should tell you something. Manufacturers have begun to warn against flushing stating it could void your warranty.
Do as you like though. Lord knows I've gone against the grain many a time.
