Inflating tires
From the 2013 MY.
For better or worse, the 2018 LS does away with the spare and uses run-flats. It will still display tire pressures by position, but folks may worry less about leaks and flats. The ride may be a bit harsher with the run flats, but it also frees up trunk space.
https://www.clublexus.com/forums/ls-...g-reviews.html
As for the run-flats, aren't the Germans also using them on their flagships?
