NX - 1st Gen (2015-2021)
Tpms
Old Nov 1, 2017 | 10:42 AM
LouisV's Avatar
LouisV
Default Tpms
hello everyone,
my TPMS warning came on even though my tires are properly inflated. It indicates my front tire left has an issue but when I performed the steps for the reset found on this forum, I have 3 tires with the warning now.
any idea what is going on?
Old Nov 1, 2017 | 11:43 AM
heffnerlex's Avatar
heffnerlex
What pressure are the tires at? The colder weather this morning would cause a drop in tire pressure which means you just have to get them topped up most likely.
Old Nov 1, 2017 | 01:20 PM
mikemu30's Avatar
mikemu30
Doesn't the indicator tell you the pressure of each tire? I think <30 psi will trigger the light.
Old Nov 1, 2017 | 01:36 PM
no1SomeGuy's Avatar
no1SomeGuy
Uh...rather than just resetting, did you check the tire pressure in that tire and make sure it's at the right pressure and make sure it's not punctured or leaking? Like wtf...
Old Nov 1, 2017 | 01:47 PM
mikemu30's Avatar
mikemu30
I had the light in my RX the other day - presumed it was the cold weather until I saw that one tire was down to 24 psi. Nail.
Old Nov 3, 2017 | 12:36 PM
LouisV's Avatar
LouisV
Of course I did. I also put more air in and around 32-33 psi and i still have 2 lights on...one went away.
Old Nov 3, 2017 | 12:45 PM
mikemu30's Avatar
mikemu30
When you say TWO lights, do you mean the individual wheel indicators which go yellow when PSI drops below a certain point? There's only ONE tire pressure warning light to my knowledge.
Old Nov 3, 2017 | 12:58 PM
LouisV's Avatar
LouisV
yes the individual wheel indicators is what i meant.
even with the pressure being raised, they remain yellow.
Old Nov 6, 2017 | 07:43 AM
rogerh00's Avatar
rogerh00
Veteran: Air Force
I had the same issue recently and had to raise the pressure higher than 32. I ended up with 36 and the light went off. The pressures vary during the day and with running time heat builds up. My car was delivered with the tires set at 42 from the dealer so I'm not worried at 36, it seems to ride better anyway.
Also if you have 17" tires you'll need more than 35psi.
Old Nov 6, 2017 | 08:26 AM
LouisV's Avatar
LouisV
my lights actually disappeared today even though the pressure indicates the same as yesterday and even with a temp drop in Canada.
jahdish
Dec 21, 2015 06:24 PM
kl323
Jan 4, 2013 02:50 PM
niteflite
Feb 26, 2010 11:21 PM
LexusPia
Oct 17, 2009 03:40 PM
mir
Apr 2, 2009 11:00 AM
