2008 ls 460 ERRATIC THROTTLE RESPONSE
Old Jun 28, 2017 | 09:49 AM
glaspk's Avatar
glaspk
Default 2008 ls 460 ERRATIC THROTTLE RESPONSE
My LS has problematic throttle response, runs fine some days other days wont respond to throttle input, sometimes to the point of barely moving through an intersection with the accelerator fully depressed. Have been to the dealer to no avail cant diagnose. Anyone else had this condition and a fix?
Old Jun 28, 2017 | 09:59 AM
sktn77a's Avatar
sktn77a
Haven't had this problem but the first thing I would try is a new dealer!
Old Jun 28, 2017 | 10:05 AM
glaspk's Avatar
glaspk
I have been to 3 dealers and driven with the auxillary diagnostics attached for nearly a month
Old Jun 28, 2017 | 10:33 AM
roadfrog's Avatar
roadfrog
This is a common issue. If you do a search of "hesitation after oil change" on this forum, you will be rewarded with a lot of info. I will reply later with my findings. It will take me a while and I don't have the time right now, lol.
Old Jun 28, 2017 | 11:37 AM
sktn77a's Avatar
sktn77a
Did it demonstrate the problem while the diagnostics package was attached? If so, what did it say?
Old Jun 28, 2017 | 12:08 PM
texas008's Avatar
texas008
I used to experience a similar issue with my 2009 LS460 almost each time after engine oil change at the dealer.
usually several days later the problem will disappear.
Then i started replacing the engine oil by myself, and haven't seen this problem ever since.
Old Jun 28, 2017 | 10:34 PM
1WILLY1's Avatar
1WILLY1
This is the one problem that scared me from getting a 460 for a while
It affected quite a few people and from my understanding it was and still is a ghost issue with no known cause or cure
Some say can be fixed by using Toyota oil rather then other brands, but I'm not sure
Old Jun 29, 2017 | 06:42 AM
sktn77a's Avatar
sktn77a
I recall some early models having their cylinder heads swapped out because of malfunctioning knock sensors retarding timing when the acellerator was pressed. Seemed like a nuclear fix at the time(?!) I was under the impression that this had been fixed. Then there was a transmission flash to address a similar problem later on. Did you discuss either of these issues as possible causes with your dealer?
Old Jun 29, 2017 | 07:49 AM
Lexuslsguy's Avatar
Lexuslsguy
It's not a mystery what causes the knock sensors go wacky. You should datalog the car and monitor those sensors to confirm. And then sell it or pay way too much for new heads.
Old Jun 29, 2017 | 02:52 PM
sktn77a's Avatar
sktn77a
Care to elaborate?
Old Jun 29, 2017 | 03:12 PM
Nguyenazn's Avatar
Nguyenazn
I think this is a feature that works exactly like BMW that i have. Its called Reset Adaptive Driving ! After every oil change, dealer suppose to reset it to let it relearn on how you guy drive, after a week it will memorize on how hard or how light you would push on the gas and it will go from there.
When ever i want to reset the Adaptive Driving on the bimmer, i just have to turn the ignition to ON, push the gas all the way in for 30 seconds, a beep will sound to confirms that the process is done.
Google : Reset Throttle or Reset ECU !
Old Jun 30, 2017 | 08:01 AM
Lexuslsguy's Avatar
Lexuslsguy
Originally Posted by sktn77a
Care to elaborate?
This is a good article. You can use a laptop and Techstream to diagnose. Just data log the knock sensors to be sure.
http://carspecmn.com/ls460-and-ls600...g-andor-p2119/
Old Jul 2, 2017 | 08:17 AM
sktn77a's Avatar
sktn77a
Thanks. Yes, this was the one I was referring to where Lexus replace both cylinder heads. I believe they only do this under the origina powertrain warranty.
Old Jul 10, 2017 | 08:19 AM
duckblue's Avatar
duckblue
I've experienced this hesitation, and it wasnt limited to after a recent oil change. I've had it happen 4k miles after an oil change.
I dont know if it is just in my head, but it tends to happen while having a tank of Exxon gas. It doesnt seem to happen as much when using Texaco or QT gas. Could be entirely coincidence, but I'm trying to monitor the occurrences more carefully to confirm/disprove my own wild guess. 08 LS460
mkhp36a
Aug 29, 2021 03:47 PM
fawski
Feb 21, 2011 01:56 PM
Xwakeboard
Sep 15, 2010 05:26 AM
mista808
Mar 18, 2007 11:02 AM
