brake squeaking when backing up.
Old Sep 29, 2015 | 11:25 AM
Lexus4me's Avatar
Lexus4me
Default brake squeaking when backing up.
2007 SWB all stock. My break squeaks when backing up, specially backing down slope on a drive way. I also notice my right rear tire have tire wears which might be related to vibration at certain speed (like 76-80)
should I check the breaks? alignment? control arms?
maybe time to search DYI on breaks and see if I can do it or not.
Old Sep 29, 2015 | 03:17 PM
is150's Avatar
is150
Is the brake sound only while backing up after you haven't driven the car for a while? If so it could just be slight humidity on the rotor while sitting, pad material (ceramic pads). If the squeal is every time you reverse I'd check pad thickness on both inside outside pads.
Have you tried re bedding your pads?
As for the rear tire wear I'd get an alignment.
Old Sep 29, 2015 | 04:58 PM
Lexus4me's Avatar
Lexus4me
It squeal often when reverse. My car is garaged, the only humidity I can think of is the dryer that runs on the weekend.
I have not tried anything yet, but thanks for your suggestions. Will do a bit search on re bedding pads first.
If I had to replace the tire(s), alignment will go after the tire(s) replacement right?
Old Sep 30, 2015 | 03:48 AM
is150's Avatar
is150
I would have the tires installed then an alignment.
Old Oct 29, 2015 | 11:21 AM
Lexus4me's Avatar
Lexus4me
Dealer charged me $165 to inspect the breaks and told me they where fine, but want to do additional inspections to look for the sound. Like ball bearing or suspensions. Every inspections will have additional charges. I am about to give up on the dealer and take my car else where.
So far I can only describe heavy squeak on reverse when using the break and with some grinding feel.
Old Oct 29, 2015 | 11:55 AM
dal20402's Avatar
dal20402
Every car I've ever had (including the LS) has occasionally had brake squeal in reverse. I think it's a normal part of life with street disc brakes.
Old Oct 29, 2015 | 12:34 PM
SC300Es's Avatar
SC300Es
My SUV squeaks all the time. I see/hear a lot of minivans squeak when going in reverse.
Old Oct 29, 2015 | 12:44 PM
dlbuckls10's Avatar
dlbuckls10
I occasionally hear that heavy grinding noise when backing up, especially after raining or high humidity but it always goes away after applying the brakes a few times and it may not do it again for weeks. I think it's humidity related and I've had the issue on other vehicles. Your rotors may looks rusty when this happens,
Old Oct 29, 2015 | 03:35 PM
dyeelitt's Avatar
dyeelitt
lube the pins on the caliper.
Old Oct 29, 2015 | 07:00 PM
Doublebase's Avatar
Doublebase
The dealer charged you $165 to inspect the brakes and found nothing? I mean, is that even legal? What's legal anymore? Why the hell anyone goes there is so far beyond me that I might mention it the next time I have my physical.
Brakes squealing while backing up could be the hardware - but the dealer thieves should have cleaned and lubed those for $165 - it also could be the ebrake assembly. Maybe there's some rust buildup, etc, just take it to a local guy, there is no reason on earth to take it to a dealer for simple brake issues.
Old Oct 31, 2015 | 05:42 AM
satiger's Avatar
satiger
If not the pads/rotor, this is the main reason for squeaking while backing up. Next time when you go for brake job, ask them to lubricate them.
Old Nov 6, 2015 | 12:23 PM
Lexus4me's Avatar
Lexus4me
When I call the dealer for break pads prices, they told me to come in for a "free" break inspection. When I drop off the car, I found out inspection is free if I do break service there. I was feeling generous that day and thinking the worse case is paying them $$$ to do the breaks.
In the end I gave up on the dealer when they couldn't tell me a clear plan to find the problem.
I end up taking the LS460 to the local shop that I always bring my Honda and Acura in. Replaced the break pads and problem solved.
I was told my control arms and bushings are good. need to see if new tires will get rid of the vibration going between 74-80mph
lesson learned, never dealer again.
F Monster
IS F (2008-2014)
37
Apr 12, 2016 10:18 PM
zaiid138
Suspension and Brakes
14
May 8, 2011 06:18 AM
ToyotaLexus
RX - 1st Gen (1999-2003)
Oct 19, 2008 06:49 PM
caymandive
44
May 30, 2007 10:48 AM
dean s
Mar 29, 2005 10:23 PM
