07 Transmission
Old Nov 7, 2013 | 09:15 AM
Amai21's Avatar
Amai21
Default 07 Transmission
Lately I have noticed that the transmission is not shifting smoothly in the lower gears. I have 114K on there. Spoke to my service manager and he mentioned that it may need caliberation. Doesn't sound right after all the miles? Has anybody experienced this problem ? Please share your thoughts.
Old Nov 7, 2013 | 12:54 PM
Chaos236's Avatar
Chaos236
Fluid been changed?
Old Nov 7, 2013 | 01:03 PM
Luxofreak's Avatar
Luxofreak
This calibration he mentioned could be just transmission software upgrade. The car "learns" the way the driver drives, and sometimes in stop-and-go traffic where you feather the gas pedal and then use the breaks right away, because the car in front of you is stopping, can cause the transmission to start behaving as you described.
What you can do is to go to an open road and take off as usual using half the travel of the gas pedal, going through at least 6 out of 8 gears. The car should go to about 3000rpm or a little more before shifting into the next gear. Usually doing this 4 or 5 times cures the problem. If it doesn't, the so called 'calibration' will just reset what the car has learned so far in terms of driver's style, and you'll teach it again in the next 2 full gas tanks or so.
Old Nov 7, 2013 | 06:55 PM
Amai21's Avatar
Amai21
Originally Posted by Chaos236
Fluid been changed?
I had the dealer change the oil right at 100K, which is when its called for.
Old Nov 7, 2013 | 06:56 PM
Amai21's Avatar
Amai21
Will definitely try it out!
Old Nov 8, 2013 | 05:43 AM
Tee's Avatar
Tee
Fluid been changed?
Transmission is sealed you don't touch it (like the 430), software update should do the trick.
14RX350
RX - 3rd Gen (2010-2015)
15
Aug 4, 2018 07:05 AM
sxn179
May 31, 2006 04:39 PM
sbsc300
Apr 7, 2006 03:21 PM
toddm
RX - 1st Gen (1999-2003)
Jul 11, 2003 08:38 AM
JT51
Sep 27, 2002 06:02 AM
