Glove Box Adjustment DIY
Old Oct 17, 2024 | 02:59 PM
  #46
jbrittmart's Avatar
jbrittmart
Originally Posted by Shibumi1
sick of lookin at my droopy glovebox door i decided to disassemble it an see what was going on back there... if the dealer can "adjust it" so can i...
here goes.. u'll need a 10mm socket,phillips head screw driver, plastic panel remover(or plastic pry), a clamp (or vise grip) black sharpie,wire cutters and a screw gun w a drill bit..
If your not comfortable w/detailed parts DONT TRY THIS..
1st: remove the passenger side console trim panel(reach under an gently pull towards passenger door) as well as the under dash panel(use finger to unlock clips). then gently pry the corner trim next too knee airbag system... with the glovebox door open pop off the passenger side dash trim panel an wood grain trim.. (use plastic pry gently start from end of dash an work towards the center) pulling out as u go..
Thank you for this guide. I just used it to get to my HVAC blend door because it was malfunctioning. Turns out the arm on the motor had just popped out of the guide that raises the door and I was able to get it back in. Everything works perfect again.
Old Dec 7, 2024 | 03:54 PM
  #47
CheapWB's Avatar
CheapWB
1st Gear
Thank you again Shibumi! I was able to access my blend door for my cabin air filter to reconnect it to its power arm, like many others here on this thread!
Old Dec 19, 2025 | 11:43 AM
  #48
Live4brew's Avatar
Live4brew
Thanks for the write-up. My arm was just dislodged and not broken. Now I have the door/arm/gasket kit available if anyone needs one (bought one ahead of time).
Advice - don't store your removed trim pieces in your driver wheel well. When I was testing the door fix I needed to put the car in ACC mode - which moved the seat back in position, snapping a mount off of the wood trim panel
Metsfan
Jul 28, 2019 10:29 AM
rodnex
Dec 4, 2016 06:34 AM
Gs21
Aug 31, 2016 08:02 PM
Bankswood
Sep 8, 2013 12:04 PM
sovok
Oct 12, 2005 02:53 PM
