Door Trim Removal
Old Sep 8, 2013 | 07:08 AM
Bankswood's Avatar
Bankswood
Default Door Trim Removal
I want to wrap my wood door trim in carbon fiber. Do I have to take the whole door panel off or is the trim held in by friction clips, meaning can I pry them out without removing the door panel?
Old Sep 8, 2013 | 07:32 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
No, Wood trim requires the entire panel to be removed. The wood trim is held in by friction rings.
Old Sep 8, 2013 | 07:54 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I think they are held in by approx. 10 nuts from the back through the door panel. Driver side has more, if I am not mistaking.
Old Sep 8, 2013 | 08:24 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
my bad...nuts, no friction rings.
Old Sep 8, 2013 | 10:47 AM
Brianmoss's Avatar
Brianmoss
What about the ones om the dash?
Old Sep 8, 2013 | 12:04 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
More trickier. Must remove the passenger side kick panel, glove box, and the trim around the center console (just below the center vent). They are held in there with wing nuts from the back side. If you have an airbag, then it is held in there by like 8 Phillip head screws on the bottom and sides. Airbag is a bit more tedious and requires more effort than one without. There are many DIY on removing this...
sc400123
Oct 27, 2021 01:16 PM
lexuz125th
Dec 28, 2014 11:50 PM
luxaro
Aug 8, 2009 07:30 AM
SoCal Cyco
Jan 19, 2009 06:33 AM
Luke_in_SD
Feb 8, 2008 05:03 PM
