Looking at these pictures, I can see how wind noise could be generated, as well as how your fix could take care of it!
Wow, those pictures certainly put some perspective on the wind noise issue and a potential root cause. I had the wind noise TSIB performed last Friday and things seem to be much better. Still some wind noise but definitely not as prominent. I'm curious whether the dealer sealed anything in the area of the pictures. Hopefully, the TSIB will be updated as I'm a little hesitant to DIY self seal my $80k car... this isn't my bathtub
Thanks for the great work MIKE_TX... I hope Lexus does the due diligence and incorporates this into the TSIB asap.
All I did was post the pictures - all the credit for the process goes to jmcraney ... see his post above.
I don't know what those square/rectangular holes under the plastic piece are for, but while I was in there, I think I'd put a strip of good heavy tape or something over them, too! The sealant around the edges ought to be enough, but just for insurance ...
The square hole, rectangular hole and round hole are for alignment and locking fingers that are part of the inside back of the plastic triangle piece. Depending on what breaks off when you pull it off you will need those holes unobstructed when you put it back on. So maybe tape is not a good idea. The sealant bead pattern I depicted (the cross stripe could be a little lower) in the photo with the yellow text provides good isolation for the three alignment holes. I drove my car again today and the improvement is really stunning. I hope others experience some improvement too.
What am I missing here? I thought the major problem with wind noise was on the driver's side window. However, according to the latest findings by jmcraney, there is a fix for the wind noise on the passenger's side as discussed above in detail. Can someone explain this to me? Can the same fix work on the driver's side? I am asking this because, I do have some swishing wind sound (only on the driver's side) with cross winds. It would be nice to eliminate even the swishing sound. But maybe, I am asking for too much.
I am sorry that I did not make that clear. I fixed both sides exactly the same. So I can't say whether one side provided a fix or better improvement than the other. I sort of got carried away and fixing both sides seemed like the right thing to do. The photo is of the right front door but if you need to know what the left front door looks like I could send you a mirror image of the same photo and you wouldn't know the difference.
jmcraney, I (and everyone else here) greatly appreciates your research and probable fix of what has been the longest discussion in history. If this is indeed a fix of the problem, Lexus ought to pay you at least a $million for discovering it. And I am being very serious here. Can you trade mark this fix?
Do you still have some swishing wind sound after this fix?
You may not have any improvement toward eliminating the swishing sound from cross winds. I think all cars have some of that under extreme conditions. My problem was roaring sound sensation up around my shoulder and poor isolation from traffic noises. The fix that I did on my car provided a big improvement for the swishing noise from cross winds but did not completely eliminate it.
