LS460 Wind Noise Fix (merged threads)
so regarding the mirror and that puddle light, using clear bra to cover up the light and make it more aerodynamic, in your opinion, did it help the noise?
My diagnostic specialist feels that it makes a difference and I trust he is correct. You are correct, it is the puddle light. He is a very smart guy when it comes to rattles, squeaks, and things like this. He spent a lot of time on this issue and came up with the 3M placement on the mirror. As a result, we are doing this with every TSIB for windnoises.
Ill be honest, my daily grind lately has been dashrattles and other interior noises. Seems like I am doing two dashes a day lately and I just dont have a lot of time with the wind noises. This is just what I have seen on this one car, and what I have learned while talking to my DS and FTS concerning this issue.
As a general statement, if the noise is as bad as Onepointon says, there's no question we'd know if we had it. And thank goodness, I don't. So it continues to appear this is a fairly rare condition, and certainly not something that affects all LS's.
I have no doubt that some owners hear wind noise, but I think it might be that some are just more sensitive to such things. It's like when I was shopping for HD TV's several years ago....some folks would see "rainbows" on the DLP sets, and I didn't see anything but an incredible picture. Or how some people listen to speakers and think they sound bad and I'm sitting there thinking how good they sound. Go figure. Maybe someone in here would get in my car and think it is noisy, but sounds pretty darn quiet to me.
Or.....maybe I got one of the good ones?
We were discussing the option of putting something in the top of the window run seal in an attempt to put more pressure on the top of the window. The problem we ran into is that is activated the pinch protection for the 'auto-up' feature of the window. The window is actually fully closed, there is just a lot of wind noise for some reason.
No doubt every car is going to have wind noise. Keep in mind that the LS460, or any vehicle for that matter, is moving a lot of air out of its way as it goes down the highway. The problem is when a customer hears a loud wind noise, they are stuck on that noise. They usually think that a dampened noise after the TSIB is not acceptable because it is technically still there, when in fact, its normal. Its really a fine line on what is acceptable and what is not. The problem is that its the customer's judgement on what is acceptable and there is really only SO much that we can do.
Romini - When you install the 3M, try to make a 1/4"-1/2" boarder around the puddle light. The thing about this is, the customer doesnt even know its there, which is nice. Let me know how you feel about the turbulence levels once its done, Im interested to know your feedback.
Do you know if there is a way to adjust the window so that it does not close so tightly against the seal?. I think this is what is causing the noise in my case.
Here is something you can try... go to Home Depot or Lowes... pick up a small pack of kitchen cabinet levelers..they sort of look like very small plastic door stops and from the side view are stairstep appearing....
With windows fully closed and from outside the car....Using 3 of them, lightly slide them to point of resistance between outer gasket and window at...when facing closed window from outside of driver side...upper left, midpoint and extreme upper right...mark them at point where sig resistance is noted...then remove and cut them to size at marker point...replace them in between gasket and window so that they do not protrude into airstream...see if that helps..if so...your situation can be remedied by interior door panel removal and tech adjusting window tensioning so that when it closes the glass is tensioned inward forced against inner seal of window frame..
The above was what I was next going to do for myself on my own for ES but traded out instead.
Onepoint you can also try that yourself next time and report back
.Sounds like a good idea, and I am not knocking it. The issue is that the window glass is not adjustable. I guess if you were determinded, you could oval out the tabs that bolt to the window regulator to get adjustment out of them, but I would highly not recommend it. I think that option would open a hell of a lot of worms and issues, not to mention the only way to reverse it would be to replace. Im sure a dealership would not warranty something like that and the glass is pretty pricey.
The other issue with shimming the door seal is activating the pinch protection on the window. We tried small objects in there, but when you press "auto-up", the window would come back down after it reached the top because it thought something was in its way of travel.
I think there are a few issues going on besides the glass. I believe there is wind coming up the interior of the A-pillar, the door frame, and a few other areas. Its a very complicated problem in my opinion.
As far as wind noise at 100mph, show me a car that doesnt have wind noise at that speed.
I have seen some customer's claiming wind noise at 90-100mph before. We simply tell them we can not drive their vehicles at that speed and no problems found.Gordy35 - I do not think there is a way to have the glass back off the seal. The only thing I can think of is to take it to your dealership and demonstrat this for a technician. As I said above, the glass is not adjustable. Maybe if they see this on a lot of vehicles, and technicians took the step to write a Product Report, maybe Lexus could impliment a newly designed window seal or way to modify it. I just dont know if thats a wide spread solution though.
The other issue with shimming the door seal is activating the pinch protection on the window. We tried small objects in there, but when you press "auto-up", the window would come back down after it reached the top.
I have seen some customer's claiming wind noise at 90-100mph before. We simply tell them we can not drive their vehicles at that speed and no problems found.As to adjusting window tension that came from a service manager who did it on an ES350 and the guy was very happy with the results, the rest of us though had to just live with it as you know there has not been a wind noise TSIB for ES350 owners in contrast to that for LS owners.
And we heard the cabin is quieter..blah..blah too..no doubt started by a "Baghdad Bob" FTS
when in reality it is and was
wind noise.And I agree with you that something may be up with the... coming in-up the A pillar as another source just looking at the seam as it approaches toward or level to hood area from an ES perspective anyway.
My understanding was they were buying back ESs while other dealers were not..
