Trunk lock
Old May 17, 2026 | 11:04 AM
trehnhazelwoodls460's Avatar
trehnhazelwoodls460
Default Trunk lock
Does everything in this damn car have to be recalibrate. My trunk stopped locking. I replaced the entire locking mechanism. Used a volt meter to check that it's getting power. Theres no obvious wiring issues. It's still not locking at all. Is this 1 of those issues that require recalibration? It looks like a simple plug & play situation.
Old May 17, 2026 | 02:29 PM
Gerf's Avatar
Gerf
Do you mean it stopped opening? or closing? You didn't accidentally hit the valet switch in the glove compartment did you ?
edit: With the trunk open can you use a screwdriver to manually lock the assembly?
Old May 19, 2026 | 06:25 AM
Bear2023's Avatar
Bear2023
Does your trunk lower automatically when you press the close button/ if it does not close automatically slowly lower the trunk manually to the locking mechanism (DO NOT SLAM) the mechanism should reset itself
Old May 19, 2026 | 08:02 PM
trehnhazelwoodls460
The trunk isn't automatic. It's manual.
Old May 19, 2026 | 08:05 PM
trehnhazelwoodls460
Tried that...
I'm not getting power now. I did the screwdriver test trick & now I'm not getting anything. Is the fuse for the truck latch in the trunk compartment?
Old May 20, 2026 | 06:16 AM
Bear2023's Avatar
Bear2023
Year and model of your car,
Old May 20, 2026 | 06:32 AM
trehnhazelwoodls460
2008 ls 460
Old May 20, 2026 | 07:11 AM
Gerf's Avatar
Gerf
I didn't know there was a manual trunk on a 460, was it made in Kazakhstan ?
Old May 22, 2026 | 11:46 PM
trehnhazelwoodls460
Back then automated trunk buttons where a option, not standard equipment
mmano
RX - 5th Gen (2023-present)
21
Nov 22, 2025 08:19 AM
Kimberly88
NX - 2nd Gen (2022-current)
18
Nov 16, 2022 09:41 AM
2UX31 YM
Jan 24, 2002 05:11 PM
