Power steering doesn’t work at slow speeds
Old Dec 6, 2024 | 10:17 AM
Jose2007's Avatar
Jose2007
Default Power steering doesn’t work at slow speeds
My 07 ls460 had ABS light on with a code for pump motor relay. After some research online and the help of the Lexus forum I was able to change the fuse box and clear the code. After that I drove the car around with computer plugged in to see if the code comes back. But while driving by mistake I pressed on EMPS and went into that setting without realizing. Red light for steering came on and steering became hard to turn. Now power steering doesn’t work well at slow speeds like under 5 or when car is stationary. I noticed that when I press on accelerator steering become easy again. But while turning or in the parking lot where acceleration is not needed the steering is really hard.Now no codes shown on the diagnostic. Any suggestions before I give it to the mechanic. Thanks in advance.
Old Dec 6, 2024 | 09:20 PM
Anfanger's Avatar
Anfanger
You need to re-calibrate torque sensors.
Old Dec 7, 2024 | 01:31 PM
Jose2007's Avatar
Jose2007
I tried that as well but doesn’t fix anything
Old Dec 7, 2024 | 01:45 PM
Anfanger's Avatar
Anfanger
Does it say that calibration was completed successfully?
Old Dec 7, 2024 | 01:49 PM
Jose2007's Avatar
Jose2007
yes I was able to calibrate it once only the same night. when I got back home to calibrate I rotated the steering wheel 90 degrees each side than centered it. Took 40 sec to calibrate than wheel vibrated to confirm but didn’t change anything. After that I tried again next night It went thru the cycle but after 40 sec it gave me an error. Let me get home tonight and I’ll add the pic of what error it shows exactly. I remember it said failed calibration
Old Dec 7, 2024 | 01:52 PM
Jose2007's Avatar
Jose2007
on my diagnostic device I can’t read codes for steering wheel. Only function available is to calibrate the torque sensor. Can a regular mechanic pull up this code or do I HAVE to take to Lexus?
Old Dec 7, 2024 | 04:32 PM
Anfanger's Avatar
Anfanger
I did it with Techstream, I am not sure what non-OEM tools can work with electronic steering.
Old Dec 25, 2024 | 12:40 PM
Jose2007's Avatar
Jose2007
Thank you so much guys. I was able to recalibrate the sensor with tech stream. Problem solved.
Klee33
RX - 3rd Gen (2010-2015)
17
Jul 9, 2024 07:26 AM
mpkayeuk
Dec 3, 2022 01:58 AM
RCoop460
Dec 13, 2019 06:54 PM
slinky
Jan 24, 2018 01:00 PM
userix
Dec 3, 2016 10:59 PM
