Dreaded engine sludge 2004 LS430
Driver side, maybe a bit better than the passenger.
Since buying the car I did an immediate oil change and we have driven nearly 4k trouble free miles. TB, WP, pulleys etc changed at a local Indy.
Did lots of reading last night and seems to be common to Toyota's secondary to the PCM. I was changing the PCV 2 weeks age and notice sludge on it. Didnt figure it would be quite to the level. Anyhow, have a couple options:
1. Aggressive - Engine flush. Mixed reviews. Many report trouble with clogged oil pick ups.
2. Medium aggressive - Clean up valve train. Run some sort of mild solvent detergent such as Rislone. Short OCI.
3. Dont poke a skunk - Finish valve cover job. Dont touch the deposits to risk dropping them into an oil galley. Better to be stuck then free.
I went with dont poke a skunk for now. Certainly there are worse pics of sludge out there on the forums but this is the worst I have seen in person since my 1964 C10 I pulled out of a field and got running. Ill keep this updated, maybe take the valve covers off after a couple of oil changes.
Careful using oil treatments that may degrade engine seals.
Use good grade of synthetic oil..Mobil 1 (0W-30), change oil filter every 2,500 (twice/oil change)
Also, change your right and left bank PCV ventilation tubes and clamps, PCV valve and PCV valve grommet..
Would not be wrong to remove oil pan to check if oil pump strainer is clogged
At 150K I changed the spark plugs and the coils. I noticed oil coming into the spark plug cylinder on one or two passenger side plugs/coils. No external oil leaks. I have yet to change the valve cover gaskets. But, could that be my oil consumption problem? Or if the PVC docent fix the problem, Is it the piston rings? All thought appreciated!
Jeff
When you change the oil add two quarts of transmission fluid (use store brand generics) and let it sit for an hour or so. It will clean it out very well without much risk to the pickup, if you use a more aggressive cleaner it can detach larger varnish bits as well and mess with other seals. Trans fluid avoids this and is way more gentle, add 1-2 cups of diesel fuel if you want to add a little more cleaning power. Be cautious with adding diesel, it won't hurt the engine from a friction standpoint but it can dislodge some pickup endangering bits......ask me how I know.
It's the one time it happened to me and naturally it just had to happen to me on a personal car.
As I mentioned above, I chose to do nothing but finish the job without doing real cleaning other than the gasket surface. I had some penzoil synthetic 10w30 on the shelf and I live in the SW where temps never get to zero. Ill run it 1-2k and change again. Unless she locks up first.
