Lock and Window Failure
Old Jun 21, 2021 | 11:25 AM
cody0r's Avatar
cody0r
Default Lock and Window Failure
I just purchased a 2003 LS 430 with only 90k miles. Everything seems to be working correctly except for two things on the same rear passenger door.
I know the motors for the locks go out, so I ordered one of those but the window will not go down either. The door will not open at all from the inside and the lock is flimsy and doesn't engage as locked or unlocked. I have not seen both of these in a single door in all my searching.
Could these be related or do I just need to change the lock motor AND the window regulator?
Other than that this car is fantastic and I am very happy.
Old Jun 24, 2021 | 01:33 AM
BigBoomer's Avatar
BigBoomer
Could be a bad earth between the door and the rest of the car.
Does the red light in the rear edge of the door come on when it is opened?
Old Jun 24, 2021 | 07:06 AM
cody0r's Avatar
cody0r
No light so I think you might be correct, I'll search for a ground issue on these threads. Thank you!
Old Jun 24, 2021 | 07:39 AM
cody0r's Avatar
cody0r
Went and looked at the fuses and it looks like the one for that door is missing. I guess the previous owner took it out, maybe there were issues.
Old Jun 24, 2021 | 07:53 AM
cody0r's Avatar
cody0r
Added the fuse and the window works but the lock still does not engage. I have the motor coming for the lock and hope that fixes it.
Old Jun 27, 2021 | 11:13 AM
cody0r's Avatar
cody0r
I got in the motor to repair the lock actuator on the passenger rear door and I took everything apart and it appears the housing has been apoxyed together, so the previous owner has had a run at this.
After I put everything back together again, now the locks on all the doors will lock then unlock every time which is probably why the previous owner took out the fuse for the passenger rear door.
I just purchased a whole other actuator to see if replacing that will fix my issues.
Old Jun 27, 2021 | 05:36 PM
JffGRY706's Avatar
JffGRY706
if child lock is on, back doors will not open from the inside.
Old Jun 30, 2021 | 01:08 PM
cody0r's Avatar
cody0r
Figured out the issue.
1. I am dumb and flipped the cables for the door lock. White goes on top, green goes on bottom.
2. I had to get in and close all doors and the lock reset itself after I got it right and hit the lock/unlock button a few times.
3. Looks like I bought and actuator and motor that I didn't ultimately need right now.
Now everything locks and is fine.
1of120
Sep 2, 2017 11:22 AM
Alex138
May 6, 2016 09:35 AM
LS400BL80
Dec 9, 2013 04:31 AM
01rxwhite
RX - 1st Gen (1999-2003)
Jul 9, 2013 03:25 PM
Luv Da Lex
Mar 29, 2008 11:49 AM
