Door handles continuously unlock when hand is over handle sensor
Old May 26, 2021 | 04:41 PM
kenaston99's Avatar
kenaston99
Default Door handles continuously unlock when hand is over handle sensor
It's hard for me to describe over text, so I made a video of what I'm experiencing. Edit: This happens on all four doors.
Old May 27, 2021 | 02:33 AM
BigBoomer's Avatar
BigBoomer
Sounds like it's doing 5 unlocks for each proximity so something in the proximity system is broken. Did you try disconnecting the car battery for 30secs to do a hardboot of the associated computer/controller.
Old May 27, 2021 | 05:01 AM
kenaston99's Avatar
kenaston99
Didn't seem to do anything. I forgot to mention sometimes when I'm driving, the dash will have a caution light saying the key is not detected. I just replaced the fob batteries with that message still appearing.
Old May 27, 2021 | 02:13 PM
LS430inDE.'s Avatar
LS430inDE.
Regarding the keyfob/batteries/key not detected message---the key detection sensor can be a bit fussy. The ashtray is a BAD location to place the keys when driving, at least in my 2005 LS. Anywhere else but the center console/ashtray area is ok for me. Experiment with different locations of storing the key. Heck--start with it in your pants pocket.
Regarding the repeated unlocking, perhaps there is a lock mechanism that is 'hanging up' and not fully unlocking? I'm guessing if the computer doesn't receive feedback that all the doors have unlocked, it will keep trying until it receives proper feedback that they're all unlocked (or all the doors that are supposed to unlock have properly unlocked).
In your video, it appears you're grabbing the passenger rear door handle? That position would command all the locks to unlock. Try unlocking from the driver's door. It should only unlock your driver's door (unless TechStream is programmed otherwise?)
Also try this....roll down all the windows and lock the doors. Then, view each of the lock/unlock latches by sticking your head into the car, and then grabbing for a door handle (on the outside, not inside). You might just find one of the lock/unlock latches aren't fully engaging to the unlock position?
Old May 28, 2021 | 05:09 AM
kenaston99's Avatar
kenaston99
I usually keep the key in my pocket and it still happens. Looking outside in all latches are fully opening when unlocking the doors.
Old May 28, 2021 | 06:11 PM
LS430inDE.'s Avatar
LS430inDE.
Wow. Now it's getting more difficult. How about the car's battery? Is it older and possibly need to be replaced soon?
The LS's can do really weird things to the electronics when the car battery is "low". While you're checking the battery, check all the ground connections and make sure they are clean and tight. I'm not sure how the keyless sensors communicate to the car or if/where the sensors/antenna are, but a broken/corroded ground could also be a culprit. Just looking at all the ground connections isn't good enough.
To ensure the ground is good, you should loosen the connection, remove the cable/wire and ensure there's no corrosion under it, and even rough it up with a wire brush or emery cloth, etc. I'd then consider spraying contact cleaner/brake cleaner/90+% alcohol/etc. After it's clean I would coat the connector/nut/post/threads with a VERY LIGHT coat of oil, similarly for the battery terminals.
Perhaps RKW can provide some guidance on the key fob sensor or antenna system layout? What year is your LS?
Old May 28, 2021 | 06:16 PM
kenaston99's Avatar
kenaston99
I will check the condition of the battery tomorrow and get back to you. It's a 2005.
Old May 29, 2021 | 06:24 AM
kenaston99's Avatar
kenaston99
I just cleaned the contacts, cables, everything like you said. Both contacts were disconnected from the battery for around 5-10 minutes while I cleaned them, it's still reproducing the same issue.
Old May 29, 2021 | 08:49 AM
LS430inDE.'s Avatar
LS430inDE.
Has this problem been there since you took ownership of the LS or you've owned it for a while and this issue just came up?
Old May 29, 2021 | 09:41 AM
kenaston99's Avatar
kenaston99
I had my mechanic replace the door lock wire in the front passenger door, but I don't recall this issue ever occuring around the time after he did that.
Edit: this was a year or two ago when he replaced the wire
Edit 2: My transmission was acting up maybe a year ago and had my ecu replaced, which fixed the issue of downshifting improperly. I don't recall my current issue ever happening after replacing the ECU.
Eastland
Oct 10, 2020 09:49 AM
Shay843
Nov 15, 2019 11:45 AM
RallyVT
Oct 31, 2017 10:16 AM
NYKnick101
Nov 8, 2013 01:32 PM
roblee8908
Sep 9, 2008 11:19 AM
