Steering Lock Keeps Locking
Old Jul 23, 2020 | 08:55 AM
Yourslinky's Avatar
Yourslinky
10th Gear
Question Steering Lock Keeps Locking
Alright so I posted a long message a couple days ago but I'm making a new thread because most of the information in there is in fact useless. To sum it up the other day my steering wheel locked but putting my key in the ignition did not unlock it and my key broke. I thought I was having an immobiliser issue after I was able to unlock it but the car cranked with no start, but then I realized the key battery was likely too far away from the ECU. Anyways, My steering lock keeps engaging regardless of how I park and the old wiggle only works after 20 mins of trying. I think it has more to do with the switch in the ignition (not ignition switch) that disengages the steering lock or something in that system.
Does anyone have any literature (diagrams, TSB's, Service manual pages, etc.) or just information about what may specifically be the issue tht they can share? Also how exactly would I even get to the ignition cylinder? I can remove the cover on the part of the steering column close to me but only one because one screw is hidden by the wheel that won't turn.
I can send video if needed as well.
Old Jul 23, 2020 | 11:44 AM
kitabel's Avatar
kitabel
My 2006 Solara (ES) must be parked with the wheels straight ahead, or inserting the key does not unlock the wheel.
Sometimes bouncing the front end helps, eventually it releases, but the dealer "never heard of it".
Old Jul 23, 2020 | 11:45 AM
430SLOwner's Avatar
430SLOwner
Maybe someone (if still on the forum) from one of these threads may be of help: https://www.clublexus.com/forums/ls-...g-sharing.html
https://www.clublexus.com/forums/ls-...not-start.html
https://www.clublexus.com/forums/ls-...ked-on-me.html
https://www.clublexus.com/forums/ls-...on-t-turn.html
https://www.clublexus.com/forums/ls-...heel-lock.html
Old Jul 23, 2020 | 02:14 PM
Yourslinky's Avatar
Yourslinky
10th Gear
This is HUGE. For some reason, even after endless searching of keywords some of these threads didn’t come up. But the first one is in fact exactly what I’m dealing with.
Old Aug 2, 2020 | 12:54 AM
430SLOwner's Avatar
430SLOwner
Also, have read ...
If your LS 430 is parked on a slope, and the front wheels are not angled properly (such as in the direction of the slope), your LS 430 ignition WILL NOT WORK. The car automatically locks up the ignition, and the car will not start until you have reoriented the front wheels. This can occur on a slight incline of around 15 degrees, and all the way likely to 40. 45 degrees...To resolve the ignition lockup (and indeed, no amount of twisting or key-insertion will turn the ignition on), one must have one's foot on the brake, rotate the front wheels from side to side, until a safe wheel angle is achieved. Then, turn the ignition slowly; if it is still stuck, redo the wheels. Once the car has detected a safe wheel position, the car ignition will work normally and you can drive off--safely.
scatton
RX - 3rd Gen (2010-2015)
Nov 19, 2017 04:13 PM
pete63
Apr 17, 2017 12:17 PM
andrew0406
Oct 30, 2015 04:25 PM
AJAA
Sep 26, 2011 11:41 PM
scyul
Mar 19, 2011 05:31 PM
