OBD2 Link Error
Old May 11, 2019 | 08:57 AM
BigBoomer's Avatar
BigBoomer
Default OBD2 Link Error
Hi All,
When I first bought my 2004 I could read the codes with an OBD2 reader with no problems.
I then bought and tried a mini-VCI cable with Techstream (never got it to work) and since then even my old OBD2 reader just gives a Link Error.
Does anyone know how to reset or fix this? I now have another VSC Off/CEL and need to read the codes to find out what it is, but can't.
I may have to resort to going to a Lexus dealer to read the codes.
Thanks,
George
Old May 11, 2019 | 06:31 PM
Yamae's Avatar
Yamae
I worry that the chip used for the communication port was damaged. This sometimes happens among cheap pirated ones. Those don't have surge protections.
Old May 13, 2019 | 06:34 AM
BigBoomer's Avatar
BigBoomer
That would suck big time. I'll take it to a Lexus dealer and ask them to read the code for me. If they can't then I have a bigger problem.
Old May 13, 2019 | 11:12 PM
razvy's Avatar
razvy
Make sure nothing it's stuck in the plug, I had a platic tab broken once and it got stock in the female plug witch prevented full contact .
Old May 18, 2019 | 09:29 AM
BigBoomer's Avatar
BigBoomer
Hi all, problem solved, was a busted wire. I removed the panel the OBD2 connector is fitted to and as soon as it came out I could see the problem.
Popped the connector out and soldered the wire back on, and hey presto we have Link.
The code I wanted to read turned out to be P0420 (Bank 1) so either I need to replace one of the O2 sensors, or else I have other problems like a leaky header-CAT gasket or a crack in the Y pipe..
I've reset it so we will see if it appears again. Hasn't so far on a 20 mile test loop.
Old May 18, 2019 | 09:31 AM
razvy's Avatar
razvy
Good Job !
Old Sep 17, 2020 | 11:45 PM
F16uae's Avatar
F16uae
Originally Posted by BigBoomer
Hi All,
Thanks,
George
hey bro same Issue with my After Scanning through techstream I am Unable to Use any ob2 scanner It just Shows Fail to link How did U get it fixed Plz reply I will be so grateful to you
Old Sep 18, 2020 | 04:31 AM
BigBoomer's Avatar
BigBoomer
My problem was that although I thought it was plugged into the ODB2 port, only the power was connected.
Try pushing hard to connect it. You will have to reach behind the socket to support it.
Once I made sure that it was fully connected, all worked as it should. 😁
makecopies
Nov 14, 2012 11:08 PM
dsouth
Jul 4, 2012 09:39 AM
dusouth
Dec 10, 2008 03:09 PM
gebo
Jul 10, 2002 11:51 AM
