Using smart key access without pushing fob buttons
Old Oct 7, 2018 | 02:23 PM
Wornout's Avatar
Wornout
Unhappy Using smart key access without pushing fob buttons
New battery in fob. Smart access button under dash is on. Fob locks and unlocks using buttons but not by gripping handle or pushing black square on handle. Any advice? 06 LS 430
Old Oct 8, 2018 | 11:04 AM
caverman's Avatar
caverman
Have you tried on all the doors? If only one of the doors isn't working then it could be a door lock actuator but it sure sounds like the button under the dash is either not on or not working.
Old Oct 8, 2018 | 11:48 AM
Johnhav430's Avatar
Johnhav430
This was the case on my car, when the driver door actuator was broken/non functional at purchase. A closer inspection showed that the driver door wasn't actually locking at all, pass and 2 rears were clicking and locking/unlocking. The salesperson (used car mgr) said no that can't be, I took your car home a few times and locked it at my house LOL
Once the dealer replaced the driver door actuator, handles worked.
(I still laugh because Yelp slammed him saying he was useless, and he was...the service mgr. is the one who fixed everything for free while he never called me back)
Old Oct 8, 2018 | 03:18 PM
Wornout's Avatar
Wornout
Thanks for the ideas. Access doesn't work on any door, button is on. Will have to have it checked.
06LS cypress pearl
99GS400 silver
98 M3 convertible
68 Chevy caprice
Old Oct 8, 2018 | 03:24 PM
aypues's Avatar
aypues
Is battery the right size?
I put one in slightly smaller than spec by accident and it worked intermittently
Old Oct 8, 2018 | 03:33 PM
caverman's Avatar
caverman
Did it work before and just all of a sudden stop? Confirm you have have a CR2032 battery and if so maybe try another one, just because it's new doesn't mean it can't be defective.
Old Oct 8, 2018 | 03:45 PM
Catalina45's Avatar
Catalina45
The 2032 is tricky to install. Will it open the trunk or otherwise function?
Old Oct 8, 2018 | 03:47 PM
Wornout's Avatar
Wornout
Battery is right. When I bought it the master key wasn't working(no battery in it), and the smart key that did work was not a master, and I assumed that was why it didn't work to access without pushing the fob
Old Oct 8, 2018 | 03:56 PM
Wornout's Avatar
Wornout
I
it opens the trunk, it lets me open the trunk by touch. The buttons on the fob work, and I can start it with key in pocket. Just can't get it to work on doors
Old Oct 8, 2018 | 07:36 PM
Johnhav430's Avatar
Johnhav430
If you push lock to lock the entire car, then make sure the fob is out of range, are all 4 doors actually locked? Or if your car is set to lock the doors when you drive off, are all 4 doors locked? In my case my driver door was doing nothing, and my symptoms were identical. It made me realize my whole life I assumed that clicking and having the car acknowledge meant all was locked. Never thought twice that if an actuator fails, the car isn't really locked. With the LS I check it every now and again....lock car, make sure fob out of range, pull all 4 handles...
Jayss01
RX - 1st Gen (1999-2003)
Jun 10, 2017 11:49 PM
jdm_altzza
IS F (2008-2014)
Jan 12, 2017 02:55 AM
JnC
Aug 26, 2007 10:14 AM
S54toIS350
May 27, 2007 11:59 AM
heavy wate
May 14, 2003 10:15 AM
