Any value in ML amps?
Old May 26, 2016 | 03:45 PM
PolishDude's Avatar
PolishDude
Default Any value in ML amps?
I have a ML amp that was replaced by the dealer less than 2 years ago, have it on my service record and have the receipt. I was thinking of possibly doing a full stereo in the LS430, what would be the value on one of these things? I know they are ridiculously expensive from the dealer but whats real world pricing on these used? Seeing if I should pull it out now and sell it or for now refoam the speakers and do a stereo later down the line.
Old May 26, 2016 | 04:33 PM
BradTank's Avatar
BradTank
You could probably get something like $300-$500, people want them as a plug and play solution if there's goes out and the unit does more than just "amplify" the audio, it's basically the controller for the whole system. So if you get rid of it you'll probably have to build a system from the ground up.
It's not worth anything for the "performance" of the unit for an aftermarket stereo, even though Mark Levinson is a big deal in home audio.
Old May 26, 2016 | 06:56 PM
PolishDude's Avatar
PolishDude
by controller you mean of the stereo portion right? I would not lose function of the navigation and climate control? My plan was the Beatsonic kit to intergrate with the factory navigation screen and from there new speakers for the front and rear along with a sub and a 5 channel amp to power it all. So I don't think I would need the factory ML amp if I did that.
Old May 27, 2016 | 06:40 AM
warminwisc's Avatar
warminwisc
If it is an ML amp it came on ML, CL and UL LS's and yes it does control nav and climate I believe. I think the whole nav unit is one piece. Check E bay for the value. Interesting I did not find a whole lot of difference between my Premium stereo in my first LSand the Levinson I now have in my Modern Luxury.
Old May 27, 2016 | 06:49 AM
BradTank's Avatar
BradTank
My amateur, non-expert opinion is that your factory screen won't operate without the ML amp unit if it's removed entirely without some sort of workaround.
But I could easily could be wrong about that. So you might want to some searches around here for people that went into an aftermarket direction.
Old May 27, 2016 | 07:31 AM
PolishDude's Avatar
PolishDude
What exactly do you mean by "one piece"? If you are imply that the radio and navi are one piece that is incorrect, that is why there is this kit
http://www.beatsonicusa.com/stereo/b...c-mva-24l.html
I am just confused why the navi or climate control screen would need the ML amp? I guess the easiest way to figure it out is just unplugging it and seeing if the screen still works.
Old May 27, 2016 | 07:36 AM
PolishDude's Avatar
PolishDude
One of the reasons I feel the amp is not necessary is all these guys that have amps that die on them, none of them mention the screen no longer working, simply that they are not getting any sound?
Old May 27, 2016 | 08:11 AM
BradTank's Avatar
BradTank
I think what happens is the amp portion of the controller goes out, but not the entire unit that has the "brain" for the screen functionality.
Just looks like to me a lot more is going on then just speaker hookups.
Old May 27, 2016 | 02:18 PM
PolishDude's Avatar
PolishDude
I need to just ask someone that has put in an aftermarket stereo lol
Old May 27, 2016 | 03:29 PM
Bocatrip's Avatar
Bocatrip
I wonder how many amps fail from old age or due to 2nd 3rd and 4th owners either trying to upgrade their systems and/or replace subwoofers and speakers with aftermarket.
Old May 29, 2016 | 10:42 PM
toantran99's Avatar
toantran99
You can remove the ML amp and your nav and AC will still work. You need the radio/cassette player
plug in. You can remove the 6 disc cd changer.
Old May 29, 2016 | 11:04 PM
toantran99's Avatar
toantran99
My ML died and didn't want to spend $300 to $700 for a used one. Replaced all the speakers, tweeter in the rear, installed a JL audio W7, JL amp 2 channel for the sub, old Kicker 4 channel amp for the speakers, 100 rms watts. Front speakers I got Momo component and for the rear speakers, Polk db component speakers.
Added front camera, turn on with a switch that you see in the dash.
While I removed the amp, I dynamat pretty much the whole car.
Old May 30, 2016 | 11:36 AM
PolishDude's Avatar
PolishDude
cool thanks thats what i was looking for
Old May 30, 2016 | 12:48 PM
toantran99's Avatar
toantran99
Your welcome.
I did not use the beatsonic kit by the way. Lost steering wheel radio control but not a big deal.
Old Jul 20, 2016 | 10:19 AM
OOO_ROB's Avatar
OOO_ROB
What kit did you use? im looking to do this asap.
HaerdenC
Jan 11, 2018 02:17 AM
Dee
Apr 15, 2015 10:21 AM
aftab242
Apr 17, 2014 10:07 PM
gsgdbeck
18
Feb 14, 2013 04:36 AM
marky2mark
Jan 12, 2011 09:42 AM
