Remote trunk opening
Old Mar 8, 2016 | 04:37 AM
IRANDY1948's Avatar
IRANDY1948
Default Remote trunk opening
THE TRUNK WILL OPEN USING THE DASH SWITCH BUT THE BLACK KEY FOB WILL NOT. DOES THIS MEAN ITS TIME TO BUY A NEW KEY, OR IS THE ANOTHER SOLUTION?
Old Mar 8, 2016 | 09:10 AM
notwealthy's Avatar
notwealthy
Originally Posted by irandy1948
the trunk will open using the dash switch but the black key fob will not. Does this mean its time to buy a new key, or is the another solution?
if you go to your local oreilley's/autozone/etc they usually have a remote tester. It will blink an led if your remote is sending a signal. Try that with your trunk button and if it doesn't work, you will probably need a new key. That said, i can't think of anything but the key that would cause what you're experiencing.
Old Mar 8, 2016 | 12:52 PM
Tom57's Avatar
Tom57
Battery in key fob replacement?
Old Mar 8, 2016 | 03:44 PM
lexman52's Avatar
lexman52
Agree with Tom replace battery in your key
Old Mar 8, 2016 | 05:19 PM
IRANDY1948's Avatar
IRANDY1948
All good info thanks for the help.
Old Mar 14, 2016 | 09:45 AM
IRANDY1948's Avatar
IRANDY1948
Default Battery
Battery replaced.....all good, thanks
Old Mar 14, 2016 | 09:48 AM
ryanSC300lover's Avatar
ryanSC300lover
easy to replace the battery in the smart key?
Old Mar 14, 2016 | 10:04 AM
LudeAEM's Avatar
LudeAEM
It is. I used this video
Old Mar 14, 2016 | 10:08 AM
ryanSC300lover
thank you!
chuck58
Jul 21, 2018 06:24 PM
caverman
Mar 25, 2015 08:17 PM
RG250
Apr 27, 2012 11:30 AM
GuoxJason
Dec 12, 2010 02:10 PM
eyeain
Aug 26, 2008 03:05 AM
