Mirrors no longer adjust
Old Jul 9, 2024 | 09:46 AM
  #136
tcarv's Avatar
tcarv
7th Gear
Default mirrors fixed.
First off-Thanks to everyone who have started/posted on this thread. My mirrors would tilt down when backing up but would not adjust in or out or up/down. After reading this forum, just did my 2004 LS430. Both mirrors work like new again. Pulling out the module was very easy-just tug straight out!! Just get your fingers tips under the lip and pull. Don't use any tools. after it's off, disconnect the three electrical clip connectors. Remove the two screws, then gently pry the switch module using a very small screwdriver or two (one on each side) from the plastic base bracket. Rock the switch back and forth to release (This was the hardest step.) Once the switch is removed, again, pry the actual switch apart with the small screwdriver(s) and open up the switch. Someone said the parts are small--that was an understatement. I cleaned the contacts with a q-tip and alcohol and did not use di-electric grease. (You can actually see the film being removed from the contacts) Reinstall in reverse order.
Old Jul 15, 2024 | 05:33 PM
  #137
Freddy12's Avatar
Freddy12
Originally Posted by Ducati11
I have an 02 Ultra lux that had the same exact problem. All you have to do is pop off the mirror control panel and clean the contacts (and be sure all of the pins are pushed into the connector). The panel is held on with clips, just grab one of the lips and pull towards you. Then depress the tab that holds the connector in place and pull off the connector (the one behind the adjustment switch). Reassemble and you're ready to go (make sure the key is on or it won't adjust.....). Hope the pictures uploaded.....
Thanks so, so much for this. Worked like a charm. A can of cleaner from Canadian Tire and mirror adjustment works again. Had figured they were goners but wondered why they still tilted in reverse. May the force be with you
Old Sep 17, 2025 | 05:36 PM
  #138
DmitryLS430's Avatar
DmitryLS430
10th Gear
Many thanks to the person who initiated this simple and effective repair! Good karma is n you, sir!
Tools and materials I used:
Small Phillips screwdriver for two little screws
Small flat head screwdriver to pry switch from housing
Tweezer
Electrical contact cleaner
Q-tip
Dielectric grease
I had to reassemble twice, because it wasn’t paying attention and reinstalled the switch the opposite way from how it is supposed to be; result - left toggle controlled right mirror and vice versa. Cute that it even works like that.
Once I pulled my head out of my a$$ and did it right, everything now works as it should. Total time - 15 minutes.
Enzima350F
RC F (2015-present)
Apr 20, 2018 02:44 PM
tdgandmsb
RX - 3rd Gen (2010-2015)
Mar 1, 2012 11:05 AM
raffles
Sep 5, 2010 07:37 AM
ILOVEGIRLS
May 4, 2007 06:28 PM
