05 LS430 mirror switch light
Old Aug 24, 2009 | 06:46 AM
hfahmy's Avatar
hfahmy
Default 05 LS430 mirror switch light
just realized that the outside mirror control switch on the dash to the left side of the steering wheel does not light up at night while driving with the lights on. Is this normal? Thx!
Old Aug 24, 2009 | 07:51 AM
jayclapp's Avatar
jayclapp
All 4 pointers (triangles, arrows, whatever you call them) on the switch light up on my 04 UL with headlights in auto or on.
Old Aug 24, 2009 | 08:22 AM
hfahmy's Avatar
hfahmy
Thanks for the quick response!
Do you know if there is a bulb behind the switch that I can replace myself? I tried mine again and they don't light up on any mode. Thanks again!
Old Aug 24, 2009 | 12:04 PM
jayclapp's Avatar
jayclapp
Don't know. Maybe someone else can help.
Old Aug 26, 2009 | 09:40 PM
BC Rider's Avatar
BC Rider
Default diy replace bulb
Mine is a 2001. Your's may be different but fwiw:
Open the coin tray
Reach under the coin tray and you can pop out the finish panel holding the two switches (mirror switch and the one right next to it)
There is a philips type head on the back of the mirror switch but the "phillips" slots are pretty thin, so a very thin flat screw driver works better for me. Anyway - that is the bulb. Unscrew it and replace it.
As far as sourcing the bulb, I expect you will need to get it from the Lexus dealer - or match it at a Toyota dealer. They seem pretty common - I have similar ones in my 1990 Toyota pickup.
Old Aug 27, 2009 | 04:55 AM
hfahmy's Avatar
hfahmy
Thanks for the tip! I took the bulb off the mirror switch and ordered replacment ($13!!!). Have another question: On the deriver side window switch, when the front lights are on, does the 3-window lock switch light up? Mine doesn't, all window switches and door lock switch do but the 3-window lock switch doesn't. Is it another bulb? How do I get it out? Thanks again!
Old Aug 27, 2009 | 08:20 AM
jayclapp's Avatar
jayclapp
Mine doesn't light up.
Old Aug 27, 2009 | 08:21 AM
hfahmy's Avatar
hfahmy
Thank you again!
swiftls460
Mar 16, 2015 12:22 AM
M88JCP
Mar 14, 2012 11:36 AM
FinLIFE
Feb 17, 2011 08:20 AM
raffles
Sep 5, 2010 07:37 AM
