Bearing Replacement
Old Jun 23, 2009 | 02:45 PM
Johnt's Avatar
Johnt
Default Bearing Replacement
My 2001 LS430 has 48,000 miles and my front left bearing is going out. It wines at various speeds. I've had the problem confirmed by two shops. Anybody else have this problem with so few miles driven?
Old Jun 23, 2009 | 07:50 PM
Nauticalx's Avatar
Nauticalx
I had the exact same one go out at about 80k miles... Got it replaced not to long ago
Old Jun 24, 2009 | 07:11 AM
pacinitaly's Avatar
pacinitaly
Unhappy
I made the mistake of taking my 2003 ultra with 65k to firestone 11/2008 for the lifetime alignment... well they took me for the $75 and another $150 to replace a lower control arm bushing on the left side ( they gave me back a piece of steel ??? ) then they said I also had to replace the right side.
Lexus wanted $490
that is why my car pulls so hard to the right. ( worst than B4 the repair )
I have brought the car back twice since and nothing done and I can't afford the $200 more to fix right now.
I'm so unhappy, and lots of other things need to be done ( brakes, timing belt, plugs, etc ) out of work since xmas
thanks for listening
~Carmine
Old Jun 24, 2009 | 07:28 AM
Nauticalx's Avatar
Nauticalx
Firestone is a joke and their techs suck at alignment...
Old Jun 24, 2009 | 07:46 AM
pacinitaly's Avatar
pacinitaly
Unhappy
I sure learned that the hard way
Old Jun 29, 2009 | 11:46 PM
usermel's Avatar
usermel
Sorry for all you've been going through pacinitaly. I hope that tomorrow brings all you need to make things better for you !!!!! You have the story of many in America fellow human,be strong!!!! L.G.N.M
Old Jun 30, 2009 | 04:37 AM
AlexusAnja's Avatar
AlexusAnja
Default Service can wait
Lexus wanted $490
~Carmine
If I read you right, you had 65K back in 11/2008, how many miles have you driven since? You won't need the timing belt and plugs until well into 100K. Brakes you want to do when necessary, but the others can wait.
Old Jun 30, 2009 | 07:57 AM
pacinitaly's Avatar
pacinitaly
thank you very much
Old Jun 30, 2009 | 08:00 AM
pacinitaly's Avatar
pacinitaly
Wink
as of today, I have 76,208
a friend looked at my pads and said I still have lots of meat (10-15k)
I can't belive I'm getting over 75k on the org brakes. I used to change my pads on my 92 camry every 50k.
I will wait. ( does my car have the interference engine? )
thanks
Old Jun 30, 2009 | 10:29 AM
LSDoc's Avatar
LSDoc
My 2001 LS430 had a similar problem at 75K miles. It was making cyclic/harmonic sounds anywhere from 25-80MPH. Happily, it was under warranty.
Old Jun 30, 2009 | 11:04 AM
I6turbo's Avatar
I6turbo
thanks
Sorry to hear you're having a tough time right not, but hang in there!
You *should* be fine on the timing belt until at least 100K miles -- that's when Toyota recommends replacing them.
The 430 engine is an interference engine, IIRC.
Old Jul 1, 2009 | 10:30 AM
pacinitaly's Avatar
pacinitaly
thank you and dang
RushNatU
Oct 22, 2018 01:46 PM
otcviper
Jun 21, 2011 01:17 PM
Stu
Nov 23, 2010 07:27 PM
Ishinc
Oct 21, 2006 04:51 AM
nudderGS400
Suspension and Brakes
Aug 12, 2004 09:31 AM
