Alignment on a UL with Data System Controller
Old Dec 9, 2008 | 11:43 AM
jman-LS430's Avatar
jman-LS430
Default Alignment on a UL with Data System Controller
This may be a stupid question but I have to ask. I assume that once you settle on a height that you will run with a majority of the time that you would take your car in to have it aligned at those specific settings?
Old Dec 9, 2008 | 01:08 PM
airtime's Avatar
airtime
CL Folding 1,000,000
I would suggest setting the car to normal height, then get the alignment. Dropping the car via the controller a few inches should not affect the alignment. Even dropping it way low will camber the wheels but should still be in alignment.
Old Dec 9, 2008 | 01:47 PM
jman-LS430's Avatar
jman-LS430
This is where I am unsure, thus the reason why I asked the question. If I didn't have a UL with DC and I put on coilovers or some other suspension change, I would have the car realigned because of the camber change (there are adjustments that can be made for camber right)? So, moving that thinking to the UL with DC, I would think along the same lines no?
I bought the car in May and it is a CPO and alignment was checked. Since then I have only put on 3K miles. Running with my stock 18" alloys with the DC in different settings, I had no alignment issues that I can tell. I am the process of installing new wheels and shoes and spent a lot of $'s so want to make sure I do the right thing and get it aligned if it is recommended to do so.
Others have opinions/thoughts on this? More would be appreciated.
Old Dec 9, 2008 | 02:01 PM
sojah's Avatar
sojah
i would always recomend someone to get an allignment done whenerver they put on big aftermarket rims especially if you spent a lot of money on the car and rims... i always did this after my first negative allignment 20" rim experience.
Old Dec 10, 2008 | 10:14 AM
BNR34's Avatar
BNR34
Agreed 100% to this thought.
Align the car with the height that you would run on majority of the time.
The camber and toe changes A LOT as the suspension go up and down.
Old Dec 18, 2008 | 05:03 PM
mafpolo's Avatar
mafpolo
Default Can you convert from air to coil/springs
Is it possible to convert an ultra to coil springs?
Old Dec 18, 2008 | 05:55 PM
BNR34's Avatar
BNR34
Of course, everything is interchangable.
Old Dec 19, 2008 | 10:54 AM
junjdm's Avatar
junjdm
I did an alightment on my car w/ the settings of 6 in the front and 5 in the rear....so far it seems to help w/ my tire wear....but its weird b/c i get faster tire wear in the front, than I do in the back.....back seems to last a very long time!
JM51526
IS F (2008-2014)
Jun 30, 2014 09:16 AM
RickJames1
Feb 21, 2010 08:58 PM
Phanatik
Jun 13, 2007 10:38 PM
gobears
Jun 10, 2007 11:50 AM
beaterKU
Suspension and Brakes
Oct 12, 2005 01:12 PM
