2004 LS430 Trunk Not Opening
Old May 16, 2024 | 03:17 PM
kingsham's Avatar
kingsham
7th Gear
Default 2004 LS430 Trunk Not Opening
New LS430 owner here. I did some searching through the forums but wasn't quite clear on a solution to my problem.
I opened up trunk this morning to put something in it. After my drive the trunk would not open. When hitting the button I could hear the mechanism engaging, but the trunk would not open. I then went thru the rear-seat passthru and used something to try to engage the internal trunk release to no avail.
If disconnecting the battery does not solve the issue, what could it be and what parts would be needed to get this fixed. Thanks. The forum helped when I was in the process of buying this car.
Old May 16, 2024 | 03:32 PM
alextv's Avatar
alextv
Did you try the mechanical key?
Old May 16, 2024 | 03:35 PM
kingsham's Avatar
kingsham
7th Gear
Yup, just tried it and nothing. Didn't open.
Old May 17, 2024 | 05:58 AM
alextv's Avatar
alextv
While using mechanical key turn and with closed hand hit top of trunk and when opened lubricate the lock assembly.
Old May 17, 2024 | 08:46 AM
kingsham's Avatar
kingsham
7th Gear
I'll try that and disconnecting the battery today. If those fails I'll have to take it in somewhere.
Thanks for the advice.
Old May 17, 2024 | 09:52 AM
alextv's Avatar
alextv
Don't disconnect battery as resetting has nothing to do with mechanism stuck. Try hitting several times while key turned. I have done this on multiple cars.
Old May 17, 2024 | 02:27 PM
kingsham's Avatar
kingsham
7th Gear
tried that method today...still didnt work
Old May 17, 2024 | 03:31 PM
alextv's Avatar
alextv
Afraid that is all I have if that doesn't work. Maybe try using a hair dryer to heat up and try hitting again. A locksmith may be able to take the lock out and spray lubricant in there. Good luck.
Old May 17, 2024 | 06:41 PM
kingsham's Avatar
kingsham
7th Gear
Think I'll try to take it to the dealership next week and see if they can figure it out. Last ditch will be getting something a little more sturdy to try and use that internal trunk release.
Old May 24, 2024 | 04:50 AM
kingsham's Avatar
kingsham
7th Gear
i tried the banging on the trunk method again yesterday and it worked....i was hitting the top of a trunk like an idiot.....hit the bottom close to the mechanism and it opened up. greatly appreciate your help on this one.
Old May 24, 2024 | 05:42 AM
alextv's Avatar
alextv
Very good. I am sure you are lubricating the heck out of it now to make sure doesn't happen again.
WallyWal
Oct 21, 2022 04:07 PM
joonbugg
Jun 12, 2022 07:31 PM
wordwrkr
Dec 7, 2016 10:42 AM
zoet101
Nov 2, 2011 12:30 PM
kg19989
Mar 24, 2010 08:26 PM
