05 ls430 UL trunk is NOT opening
Old Jun 12, 2022 | 07:21 PM
joonbugg's Avatar
joonbugg
1st Gear
Default 05 ls430 UL trunk is NOT opening
Today my trunk decided not to open. Have a 05 LS430UL . The internal trunk switch located next to the gas cap does not open the trunk, when it is pulled it no longer pops the trunk like usual. The trunk lock is OFF. The finger trunk switch on the outside of the trunk is completely non responsive. Even tried manually unlocking the trunk from the outside with my key and it does not work. I can’t get to the trunk thru the back seat to pull the lever from the inside of the trunk since i have a UL with a cooler . Any ideas on what the issue is and how it can be fixed without going to the dealership???
Old Jun 12, 2022 | 07:31 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Did you push in the valet lock button? Check that, put key in and unlock it
the linked thread has a picture if you don’t know where that is
https://www.clublexus.com/forums/ls-...se-button.html
rickster9
Sep 20, 2024 02:45 PM
wordwrkr
Dec 7, 2016 10:42 AM
shiny250
Mar 12, 2010 08:13 AM
dreambig
Jul 12, 2009 07:28 AM
rodel
Jan 9, 2004 08:48 PM
