gate Shifter Swap?
Old Oct 6, 2010 | 03:01 PM
808UCF11's Avatar
808UCF11
Default gate Shifter Swap?
Is it possible to swap ucf20 gate shifter into first gen, without a trans swap? if so what needs to be changed? and has anyone here done it successfully? or know someone who has?
Old Oct 6, 2010 | 03:07 PM
3UZFTE's Avatar
3UZFTE
Yes, search. You will need the full shift assembly from the UCF20 with the gated shifter. I think you'll find this handy. https://www.clublexus.com/forums/per...pre-98-sc.html
Old Oct 6, 2010 | 03:13 PM
808UCF11's Avatar
808UCF11
damn i tried searching under "gate shifter" "gate shifter swap" gate shifter mod" but no luck. but thanks 3UZFTE, i appreciate the help
Old Oct 6, 2010 | 06:26 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
make sure the shifter is from a 95-97 LS.
Old Oct 6, 2010 | 08:14 PM
BLKonBLK98's Avatar
BLKonBLK98
thanks for the info, this has been on my list of things to do. pic from onestar.
Old Oct 6, 2010 | 08:57 PM
808UCF11's Avatar
808UCF11
thanks for the info, what exactly do i need? there's a local 97 that's being parted out.
EDIT: never mind i just checked the local craigslist add... it's a 98
Old Oct 6, 2010 | 08:58 PM
808UCF11's Avatar
808UCF11
wow that pic looks good bLKonBLK!
Old Oct 6, 2010 | 09:12 PM
PureDrifter
BahHumBug
CL Folding 100,000
actually you may be able to use the 98's, and use the switch to 4 as an O/D switch.
Old Oct 6, 2010 | 09:32 PM
808UCF11's Avatar
808UCF11
ok i'll look into that, thanks bro. so if i find a 95-97, is it any easier swap?
Old Oct 7, 2010 | 09:58 AM
Garage7RP's Avatar
Garage7RP
Swap is both mostly mechanical and may have to use parts from both shifter to make it fit right. There are no detailed swap here but you need to study both shifters.
paul1012
Oct 2, 2013 08:15 PM
TANE
May 30, 2010 12:43 AM
thebadz32
Dec 27, 2007 03:16 PM
