Sponsored by: CARiD
Silverstar problems
Old Nov 3, 2002 | 02:35 AM
broke_gs's Avatar
broke_gs
Default Silverstar problems
I ran into a problem today trying to put the Silverstar 9005 into the 9006 headlight slots. The one on the driver side does not light up. It's not the bulb because i switched the bulb and it still doesn't light up. If I put the old stock ones back in, it works fine. The terminals are not bent or anything. Did anyone else have this problem and what did they do?
Old Nov 3, 2002 | 03:30 AM
rominl's Avatar
rominl
exclusive matchup
the terminals are swapped on the driver side. sometimes bulbs are made with + and - the same way, but that's not the case on the lex i guess. using a tiny flat head screwdriver you should be able to unplug the head of the power connect of the car and swift the two
Old Nov 3, 2002 | 10:05 AM
broke_gs's Avatar
broke_gs
I'm going to try this, but I don't know if that's the problem. Because if it was, I wouldn't be able to switch the 9006 bulbs from passenger to driver side, they would be side dependent also, but they are not. At this point, I'll try anything.
Old Nov 3, 2002 | 11:47 AM
broke_gs's Avatar
broke_gs
Ok, I'm an idiot. I discovered the problem. The 9005 is not designed to fit in the 9006 socket. When you try to put it on, you're actuallty forcing the 2 ribs in the bulb into the plastic on the harness. Since I hand-pushed the first bulb, I thought it would also be the case with the second one. Apparently I didn't get it in far enough and had to resort to pliers. Just FYI.
Old Nov 3, 2002 | 02:36 PM
rominl's Avatar
rominl
exclusive matchup
oh... i thought you somehow fit the 9005 into the 9006
Old Nov 3, 2002 | 03:09 PM
GSquicksilver's Avatar
GSquicksilver
actually, from what i heard, 9005's are highbeam lights, not regular lowbeams. that's why they're brighter too.
Old Nov 4, 2002 | 10:58 AM
broke_gs's Avatar
broke_gs
romnil, I did fit the 9005 bulb into the 9006 plug. It fits ok, you just have to force it in. And they are brighter than the 9006 bulbs. I'm happy with it. That plus I could take the 9006 silverstars I had in the head lights and move them to the fog lights. It makes a huge diffence in the fog lights.
Old Nov 4, 2002 | 11:41 AM
brendanlim's Avatar
brendanlim
Here's a thread of mine about a month or so ago.
I "easily" popped in 9005 Silverstars into my 9006 harness.
Got 9005 silverstars as my headlights and 9006 silverstars as my fogs.
https://www.clublexus.com/forums/sho...r&pagenumber=4
EZLex
May 13, 2018 10:54 AM
bebadman
Jan 24, 2018 04:58 PM
UNCGS06
Oct 11, 2010 10:19 AM
JemmyTran
Feb 19, 2010 05:21 AM
cknjohnny
Jan 28, 2010 05:07 PM
