Suggestions...
Old Dec 19, 2002 | 04:33 PM
futuregs's Avatar
futuregs
Default Suggestions...
Getting Two Rockford 12" (I think Punches) with a Rockford 800.2 AMP. Will I need to dynomat my GS? Any recommendations on how box should be placed?
Old Dec 19, 2002 | 07:28 PM
pcmw's Avatar
pcmw
Dynamat or other sound deadener will help with rattles and road noise. Apply to the trunk before installing the box will make a difference.
I really like the GS with the box between the shock towers. Speakers facing the back bumper and a port thru the factory location.
MW
Old Dec 20, 2002 | 01:19 AM
Miles B's Avatar
Miles B
Hyundai Driver
If you're going to play it loud, get ready for your car to develop some new rattles after a while.
Ask me how I know.
Old Dec 20, 2002 | 03:24 AM
Jmai22's Avatar
Jmai22
don't use dynamat. use some sort of other sound deadening. yes you will need some.
Old Dec 25, 2002 | 06:04 AM
elclassico's Avatar
elclassico
Arrow true
Ask me how I know.
How? j/k the main problem is the back dash, and the front dash where it meets the windsheild. the rear speaker cover is a ***** to get off, pretty much need to break the rivets. but that speaker cover/ rear break light make too much noise rattles for me. i just took mine completlly off. problem solved
im running 2 jl 12s with a 600 watt amp. sealed box between the towers. amp has adjustable bass gain control from the cabin, which is key because adjusting the bass at the wheel is crucial. i am happy with the sound, but new rattles can drive you crazy sometimes. you just got to hunt them out. hope i helped, good luck
Old Dec 25, 2002 | 07:36 PM
Miles B's Avatar
Miles B
Hyundai Driver
Heh heh yeah I run a 1800x1 RMS... it just *makes* rattles. After a while, all kinds of parts have been bounced and moved that much that they don't quite fit together right any more, and they rattle. Kind of a whole car rattly squeeky deal. Needless to say, the amp is for sale and not going into the Lexus! And yes, with that kind of power, bass control from up front is essential if you want to keep your hearing or licence.
Old Dec 26, 2002 | 02:51 PM
Kyle Harty's Avatar
Kyle Harty
The sound deadening mat will be needed, but there are a few other methods to attacking rattles. Expanding foam can be great for filling empty space between sheet metal, like inside the trunk lid, that sort of thing; just be real careful not to overfill (since it does expand a fair amount) and put plastic or something down so you don't get it on the car or trunk. Also, if you can find sheets of soft, open-cell polyurethane foam about 1/4" thick, that works well to put behind or between panels that rattle together to isolate them.
Old Dec 26, 2002 | 03:13 PM
Jmai22's Avatar
Jmai22
where can i buy expanind foam at?
Old Dec 26, 2002 | 04:58 PM
pcmw's Avatar
pcmw
Jmai22,
Home depot sells expanding foam by Great Stuff.
MW
Old Dec 26, 2002 | 05:34 PM
retrodrive's Avatar
retrodrive
Search Function Inc.
Be real careful with the expanding foam. Pick one that expands the least and use just a little of it. Foams can bend metal and crack plastic easily when they expand.
As for rattles, Lexus is a fairly well sounddeadened car. After you install your subs you will know whether you need sounddeadening or not.
Old Dec 27, 2002 | 01:33 PM
ebruce2's Avatar
ebruce2
future, I have a pair of Kicker Comp 10's in a bandpass enclosure being pushed by a Kicker 700.5. It's not a ton of power, and there is a minor license plate rattle at higher spl. The quality of construction of the GS surely absorbs a great deal of noise. Sound damping material would be a good idea though.
As for speaker placement/direction, what my installer found was that the subs facing backwards gave the best output.......and definitely remove the stock sub to allow the subs output to be ported into the cabin. Good luck!!!!
Eric
Old Dec 28, 2002 | 04:41 PM
Kyle Harty's Avatar
Kyle Harty
The warning on the foam is definately worth mentioning again, I've heard of but haven't used a Latex expanding foam that wouldn't crack or bend panels, that'd probably be worth looking for if you're concerned about wrecking panels. I've always used Great Stuff Minimal expanding foam, I'd stay away from the Triple Expanding stuff just for the reasons retro mentioned.
The license plate is a prime candidate for the other foam I mentioned. I don't know where you'd be able to find it, maybe a craft store; I get it from work.
If this picture works, here's what the foam looks like on the back of a license plate.
fatalvirus
May 29, 2019 05:06 AM
jagged
RX - 3rd Gen (2010-2015)
May 27, 2013 09:31 PM
dashan
Jul 5, 2009 12:41 AM
Pheonix
Dec 20, 2006 07:02 PM
dgtbullet
Jan 3, 2003 09:56 PM
