Battery
Old Jul 7, 2022 | 12:04 PM
  #121
355F1's Avatar
355F1
Originally Posted by RysLC500
I know right. I bought it off a family friend for 10k last year. Has 209k miles and runs like a champ. So smooth and powerful. They were built like tanks but ride like pillows. Had a few people drive by and want to buy it from me. Never took it off road but hear its one of the best (if not best) OR vehicle ever made. Even has a backup cam which in 2005 was a big deal lol
My brother has a 2012 (I think?) LX......200k miles and it gets so much off-road use up in the mountains at his weekend house. I think he loves it more than he loves his RR Autobigraphy.
Old Jul 9, 2022 | 09:29 PM
  #122
ttantioch's Avatar
ttantioch
Default Battery charge
Got my battery change in the Lexus dealer for 350$. Wanna try other batteries(higher CCA and around 200$) but workers are too fearful to work on LC as they took too much risk for free installation service.
Now I have a battery charge issue, I read the manual pg 258:" disconnect your ground cable when recharging"
Did you guys do that? And How?
Old Jul 9, 2022 | 10:30 PM
  #123
Brinylon's Avatar
Brinylon
It says the same in my manual, but I have a battery maintainer permanently connection and in turn connect that to power. No problems whatsoever, and I suspect this instruction may be in regard to preventing/minimising sparking which could in theory ignite any hydrogen gas that may be present. Dead easy to follow the advised protocol, but out of interest, what is your "battery charge issue"?
Old Jul 9, 2022 | 10:35 PM
  #124
ttantioch's Avatar
ttantioch
Originally Posted by Brinylon
It says the same in my manual, but I have a battery maintainer permanently connection and in turn connect that to power. No problems whatsoever, and I suspect this instruction may be in regard to preventing/minimising sparking which could in theory ignite the hydrogen gas. Dead easy to follow the advised protocol, but out of interest, what is your "battery charge issue"?
It is " I want to charge battery safely (the manual is telling me a horror story about releasing flammable gas that could cause a fire or explosion), but the manual says to disconnect the ground cable, which I do not know if I should do it and how to do."
Your response is "I charge the battery but not following the manual, but so far it is fine"
Old Jul 10, 2022 | 12:04 AM
  #125
Brinylon's Avatar
Brinylon
Personally I think the chances of an explosion or some such are somewhat over stressed. The reality is hydrogen gas is lighter than air and therefore will literally float away once the battery cover is lifted but if you were ultra cautious then physically fan or blow it away. If you don't know how to disconnect the earth then it may be you should entrust this task to someone who is mechanically competent?
Old Jul 10, 2022 | 05:11 AM
  #126
BruceinFla's Avatar
BruceinFla
I'm sure it's a product liability issue. Lawyer speak.
There's an absolute micro minimal chance of any battery explosion.
On the other hand, IF the remote Does Occur, the ramifications of an exploding acid container on the consumers face and chest warrant erring on the side of extreme caution.
Bruce in FL
Old Jul 10, 2022 | 09:15 AM
  #127
MLMLC52K18's Avatar
MLMLC52K18
I had to recharge my battery 7 days after delivery...I didn't connect directly to the battery in trunk. Instead, I used the terminal in the engine bay and grounded to metal...Car did not explode! I think these instructions apply to direct battery charging. And if you choose to do it that way, then simply disconnect the black cable before charging as instructed.
Old Jul 10, 2022 | 01:07 PM
  #128
ttantioch's Avatar
ttantioch
Hard to find someone to disconnect my ground cable each time I want to use the battery charger lol
Old Jul 10, 2022 | 01:13 PM
  #129
MLMLC52K18's Avatar
MLMLC52K18
Duh....Then use the terminal under the hood. And you don't disconnect anything!
Old Jul 10, 2022 | 01:29 PM
  #130
ttantioch's Avatar
ttantioch
I dont know why but my charger will reject the terminal in the hood, it will show 6V and stop charging. Have to use the real battery in the truck.
Old Jul 10, 2022 | 01:42 PM
  #131
MLMLC52K18's Avatar
MLMLC52K18
Are you grounding the black cable from charger to a piece of metal under the hood? It shud work.
Old Jul 10, 2022 | 01:50 PM
  #132
ttantioch's Avatar
ttantioch
Yes, the cable is too short to reach the suggested ground part under the engine cover, so I have to pick a piece of metal near the fuse box. But for my charger it does not work
Old Jul 10, 2022 | 02:30 PM
  #133
MLMLC52K18's Avatar
MLMLC52K18
I'm confused. Can tell me how long your cables are & maybe post a pic of your charger?
Old Jul 10, 2022 | 02:33 PM
  #134
ttantioch's Avatar
ttantioch
like 1.5* length of iphone
Old Jul 10, 2022 | 02:47 PM
  #135
MLMLC52K18's Avatar
MLMLC52K18
Doesn't sound like any changer I've ever seen. Most have at least 24in cabling. If they are that short you need a real charger.
