LC500 spontaneous frame crack (or something else?)
Old Mar 12, 2025 | 06:47 PM
  #136
microsup's Avatar
microsup
Yep, same here, first day after winter, no clicks in the morning below 70 deg. On a way back 78 top down no clicks. Hope maybe it is gone
Old Mar 17, 2025 | 09:08 AM
  #137
danibear's Avatar
danibear
Originally Posted by antidentit
I finally figured out how to fix the rear squeaking noise myself and it took my just over an hour. It's also pretty easy to do, even for someone who's not very mechanically inclined - like me. Here's how I did it and the tools I used (it cost me about $30 with supplies left over):
https://www.clublexus.com/forums/lc-...ing-noise.html
If you do try it and figure out how to detach the wire from the rear seat belt, that would make this DIY even better and easier!
Have you considered using thread sealer like Loctite thread sealer (Blue - removable) or (Red - permanent - still removable just need more break torque)?
So that you do not have to re-do this periodically.
Old Mar 17, 2025 | 09:48 AM
  #138
antidentit's Avatar
antidentit
I considered it, but I ran across a thread that did not recommend using any type of Loctite for this fix. I don't remember where I read it, or why the recommendation, and don't have enough experience one way or another to try it. But if my attempts above don't last as long as I hope, I'd be open to try it the next time I service the bolts.
Old Mar 17, 2025 | 12:16 PM
  #139
MostlyParked's Avatar
MostlyParked
4th Gear
If you decide to go that route, I would suggest Permatex "Orange" 25210: High Strength Removable/Serviceable thread locker about 4 times the strength of Blue. Clean all threads before using, personally I like to use MAF cleaner, cleans as well as "brake cleaner" dries as fast too but is safer around plastics.
Personnel note about the "Orange". Don't use on anything 5mm and smaller going into aluminum threads. I used it on some 5mm screws that were holding a air filter backing plate and air horns to some Weber DCOE carbs, I nearly lost some threads removing them. When I reinstalled I use a flanged screw with locking wire, the orange would have worked very well if I had not needed to remove for a access to a throttle cable.
Old Jul 28, 2025 | 07:22 AM
  #140
Badhobz's Avatar
Badhobz
Its warm out and yesterday i heard a bunch of plasticy squeaking from the passenger side rear B pillar area. I had the top up so it was noticeable due to how quiet these cars are. With the top down its a non issue.
You guys experiencing this more so in the summer?
Old Jul 28, 2025 | 11:38 AM
  #141
2959's Avatar
2959
I've not noticed any abnormal sounds when the tops up. And your correct about how quiet it is. We were coming back on the highway and I kept hearing a rattling sound that was driving my crazy, like change in a plastic cup. Found out it was a water bottle, the little plastic piece that breaks off the cap (seal protection?) at the throat was the culprit.
LexuScott
Nov 7, 2017 07:37 PM
Orthodoks
IS F (2008-2014)
Sep 5, 2016 08:38 PM
matts6887
RX - 1st Gen (1999-2003)
Dec 31, 2015 08:13 AM
kidalex
Dec 18, 2007 08:30 AM
hung8852
May 31, 2007 06:00 PM
