Exhaust valves
Old Aug 19, 2025 | 05:01 PM
  #211
TTBomB's Avatar
TTBomB
Can anyone help with this...
I also have a 22 Convertible and pulled the fuse when the car was turned off.
At initial startup the exhaust is noticeably much louder, however it does seems to quite down once it runs for a bit (maybe 20-30 seconds). Not sure if the valves are closing causing after that or if its the tune once the car warms up.
It does sounds a bit louder while driving with the fuse removed but its no where as loud as first start up.
Maybe someone here can shed some light on what's going on here.
Thanks
Old Aug 19, 2025 | 05:34 PM
  #212
np20412's Avatar
np20412
Thanks
What you describe is just the normal vehicle behavior regardless of valve status.
That is just the startup when the engine is revving quite a bit higher for the first 15 seconds or so after that the revs drop a little and the sound quiets. Don't quote me but I think it's because both exhaust valves AND intake valves are open during this sequence, after which the intake valves close and the sound quiets a little. To my understanding there is no way to maintain that initial loud growl beyond that time.
The same happens on my armytrix exhaust which has valves 100% open all the time. The initial cold start is very loud for 15s, then it quiets a bit. If i close the valves at that point it quiets even more.
Old Aug 19, 2025 | 05:49 PM
  #213
TTBomB's Avatar
TTBomB
Ok appreciate the feedback!!
Old Aug 20, 2025 | 04:45 AM
  #214
barncobob63's Avatar
barncobob63
normal on mine.
Old Oct 18, 2025 | 05:35 AM
  #215
sachmthom's Avatar
sachmthom
I was following this video which said there are two plugs on each side. Mine is 2024, I could only find one on each side. Am I missing something?
Old Oct 18, 2025 | 05:15 PM
  #216
sachmthom's Avatar
sachmthom
I just read saw some comments saying even pulling plugs from under the car wont work longer for 2024+ models.
Like it will stay open and later it will close permanently after some time so that you plug them back in for it to open again. Any truth in this?
Old Oct 20, 2025 | 05:55 AM
  #217
iltrav's Avatar
iltrav
Did the same. They should stay open as they need the fuse to actually close. Startup is always much louder, but you should notice a good amount more sound in the 3000-4000 range when driving. Honestly open valves are not a huge difference but does sound better/louder, especially if you have a convertible and get to hear things more clearly. Agree, sounds normal.
Old Oct 29, 2025 | 12:31 PM
  #218
Cooker883's Avatar
Cooker883
Originally Posted by pottypants
so spill the beans
how does one make the oem flaps remain open ?
default is open so disconnect ?
Magic blue pill installed…
Magic blue pill removed…
[img alt="…and here’s the magic blue pill! Removing it increased warm idle sound energy by 2 or 3 decibels (A-weighted scale). 2018 LC500, 37,000 miles. Big difference until you get the gas open hard, when the muffler valves would be open anyway. OBD showed no codes with this fuse pulled. Car sounds even more fantastical than it did stock, but no change I am aware of re fuel economy.
Lots easier than unplugging connections under the car. "]https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/920x2000/img_5145_4673712df71d2c2b355bca359cc2e4013e808749.png[/img]
…and here’s the magic blue pill! Removing it increased warm idle sound energy by 2 or 3 decibels (A-weighted scale). 2018 LC500, 37,000 miles. Big difference until you get the gas open hard, when the muffler valves would be open anyway. OBD showed no codes with this fuse pulled. Car sounds even more fantastical than it did stock, but no change I am aware of re fuel economy. Lots easier than unplugging connections under the car.
Old Oct 29, 2025 | 04:10 PM
  #219
rmbrewer's Avatar
rmbrewer
Originally Posted by sachmthom
https://www.youtube.com/watch?v=13v_tdArJsY
There is only one plug for your 2024
Old Oct 29, 2025 | 08:00 PM
  #220
Cooker883's Avatar
Cooker883
Sorry. Here’s the magic blue pill: 15-amp fuse. Photo didn’t originally post.
Old Jan 14, 2026 | 11:18 AM
  #221
tecman's Avatar
tecman
After almost three years of thinking about it, forgetting about it, and putting it off, I finally pulled the fuse on my 2021. I drove the car for the second time yesterday. It has a little more volume, sounds fine to me, so I think I’ll leave the fuse out.
Old Jan 14, 2026 | 05:32 PM
  #222
orien's Avatar
orien
Where did you read that?
Old Feb 3, 2026 | 10:08 PM
  #223
Uchinanchuu58's Avatar
Uchinanchuu58
1st Gear
Originally Posted by ItGoes
No downside! If you already have it like that, there is no need to adjust.
I enjoy doing this type of "hacking" stuff! Hopefully a few other people can benefit. I will post all the designs and code once I am finished so other people can recreate it.
I will have further updates of my findings/development in this thread if anyone is curious.
Hey there, I'm Tim, the guy from Okinawa, Japan who was trying to buy your exhaust valve remote control through Etsy back in December. After I consulted you about APO shipping and placed my order, Etsy decided to cancel the order and suspend my account for no known reason, presumably because they thought I was some kind of fraud. Etsy customer service initially responded when I tried to get my account reopened, but once I sent them the information they requested to verify I was the actual account owner, they stopped replying, and I still can't log in to my account. No idea what's going on there. In the meantime, I had left a comment on your Youtube video about installation of the controller to get you to reach out to me, but I don't think you've seen it yet, or I missed your email if you sent me one. And on this forum, I don't see any way at all to send you a personal message, hence my posting in this thread in hopes that you'll get a notification.
But anyways, I would still love to purchase the controller from you. If there's a way to PM me here, please do that, or email me at uchinanchuu58 at gmail. I have Paypal (through a different email address) if that's the best way for you to receive the payment.
sdqqbb
Mar 11, 2017 03:34 PM
yonexyr
Performance
Sep 14, 2015 07:49 AM
